Results 1 to 6 of 6
Thread: RIDGID 15in Standing Drill Press
    Need I Say More.... PHFIRENO7783's Avatar
    444
    Looking to get $200 for it.....We'll talk about pick up. Im going on vacation now so I'll post pics when I get back.
    P.S. I only used it one time
    This heavy-duty stationary drill press is loaded with conveniences that enable quick, efficient and uniform drilling across a wide range of surfaces. A tilting woodworking table with large clamping edges and 4 mounting slots gives you an extremely versatile work surface that can be adjusted to meet the needs of each job. The large-capacity throat depth allows drilling to the center of a 15 In. workpiece and 12 different speed settings allow you to optimize the drilling rate so it matches any material type.
    • 5/8 In. capacity key chuck accepts a variety of standard bit sizes for varied projects
    • 1/2 hp induction motor is fan-cooled and totally enclosed with enough power to bore through tough materials
    • 12-speed spindle with a range of 300-3,100 rpm gives you the speed you need to handle all kinds of jobs
    • Left/right hub allows positioning of the crank handles on the left or right side of the head for versatile use
    • Poly-V drive belt limits vibration and improves power transfer for more efficient, robust operation
    • Includes smooth actuating rack and pinion table elevation, quick-release belt tension lever and a built-in light for efficient working conditions
    • Solid cast-iron base, table and head with heavy-gauge tubular steel column provide a strong, stable working environment built for long-lasting performance
    Bill
    2006 Ford F-250 CC
    6.0L V8 Turbo Diesel
    Ted Nugent For President-2016
    http://www.tednugent.com
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Did you ever sell this?
    Mark Lowry
    444
    No I didnt
    Bill
    2006 Ford F-250 CC
    Member DING's Avatar
    New Bern, NC
    324
    Do you still have this? I will be in Pittsburgh the weekend of Feb 15th - 19th. PM me you number so we can set something up. Thanks Hank
    Hank
    444
    PM sent....
    Bill
    2006 Ford F-250 CC
    444
    SOLD
    Bill
    2006 Ford F-250 CC
  1. standing mile
    By Cam99 in forum The Bar
    Last Post: 09-06-2011, 01:06 AM
  2. Ford GT Sets New Record for Standing Mile at 253 mph
    By mlowry1260 in forum Pictures & Videos
    Last Post: 03-24-2010, 07:36 PM
  3. WTB: nice floor standing speakers
    By jaa55 in forum Wanted
    Last Post: 08-12-2009, 10:51 PM
  4. bench top drill press
    By 94svtcobra in forum The Bar
    Last Post: 03-11-2009, 06:32 PM
  5. 15in DOT slicks or DR
    By lib88stang in forum Ford Parts
    Last Post: 05-20-2007, 10:47 PM
