Results 1 to 20 of 36
Thread: which motor is better for a TT?
    I decided i am going with a TT setup and now i am wondering which motor would a tt kit work the best on a pushrod or a mod motor? I have the 302 now and was thinking about it and thinking i would get more out of amod motor so i started looking around for a 96-01 cobra. What are yins imputs?
    3,316
    I would say "it depends"
    I've always been a fan of OHC setups, so I would go with a mod motor. regardless of which motor you go with, the parts making up the twin turbo kit are going to be relatively the same with respect to turbo size and intercooler (the most expensive parts of a TT setup). To me, it comes down to the age old question:
    How fast do you want to spend?
    I think it should go as follows:
    1.) Shortblock: Keep the 302 for increased displacement – however take the factory piston's and bolt a .250 thick steel plate (321ss) on top of all (8) pistons to raise compression to 18:1 (more on this later)
    2.) Heads: Find one 96 cobra head (drivers side) and one 5.4 2000 Cobra R head (pass side) – remove both your 302 heads and put these DOHC heads on in place of them. Be sure to keep your stock 302 cam in there as well (more on this later)
    3.) Intake – Use a 2JZ intake manifold…ported and polished with twin 03 cobra T/B’s
    4.) Turbo Kit – Buy Viper Ed’s single kit
    Now for the kicker to put you ahead of the pack: Remove all spark plugs in the DOHC heads…and get them machined for a 5th valve….This will be an additional exhaust valve to help spool up…you will be at full spool by 2k rpm easy. Use the 302 cam (see item 2) to operate this exhaust valve for…….yes that’s right……….a 5 cam setup. This little trick will be worth an easy 100hp.
    But you’re going to ask…well if I remove the spark plugs to put in a 5th valve/cyl, what about the spark plugs??? Well glad you asked…that’s the beauty of it really…(see item #1)…the increased compression of the steel plate on each piston will negate the need for spark ignition…as now the compression alone will be enough to ignite the mixture.
    Let me know your thoughts…..
    Hi I'm Stupid 393rag's Avatar
    FayetteNam
    889
    Now for the kicker to put you ahead of the pack: Remove all spark plugs in the DOHC heads…and get them machined for a 5th valve….This will be an additional exhaust valve to help spool up…you will be at full spool by 2k rpm easy. Use the 302 cam (see item 2) to operate this exhaust valve for…….yes that’s right……….a 3 cam setup. This little trick will be worth an easy 100hp.
    You lost me here...but it sounds really awesome.
    i am definetly lost
    Ligonier, PA
    6,365
    f*** it scott....just build a 5.4L twin turbo.....nothing will touch you...lol
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    Spencerport, NY
    3,762
    Quote Originally Posted by 2001GTTT View Post
    except you'll still be looking at my taillights!! hehe
    2015 Corvette Z06
    - Shark Grey / Kalahari
    I'm your huckleberry, why thats just my game
    Banned George C's Avatar
    1,490
    how is that possible?
    1,490
    yes this is the way to go!
    Spencerport, NY
    3,762
    stfu someday
    2015 Corvette Z06
    1,490
    stfu someday
    well make that someday soon....
    I like hair dryers Twin01cobra's Avatar
    Wherever I want
    1,270
    Look at the numbers in my sig, that's on a 4.6 with stock heads, cams, intake, etc. The only thing not stock is the built bottom end. And it's just warming up
    General Douglas McArthur
    Quote Originally Posted by Twin01cobra View Post
    yea thats what i have been looking at is the mods compared to the pushrods and it seems that the mod motors get alot more horsepower out of the same setup as a pushrod does.
    exactly...that's what im' saying man...keep the 302 shortblock with 18:1 and use the mod motor heads...with the 5th valve...then you have an OHC and OHV all in one
    3,316
    man you guys are clueless about performance.
    Dont listen to them, they dont know anything. Here's what you do if you want to go fast.
    Start with the 4.6 mod motor and forget all this OHV/OHC combination crap. Go to the junkyard and get a pair of heads from two 2.3 liter VTEC engines that were in accords. The domestic/vtec combination will be unbeatable and you could probably run in the 8's, maybe high 7's with a good tune.
    Too late...it's already been done.
    I'm telling you Scott....stay ahead of the game....the secret is the 4.6 and 5.4 head combo in the exact orientation I mentioned....it's in development at Ford and MMFF will soon be covering it.
    3,316
    No, the SOHC vtec head was done, but not the DOHC vtec head. He'll have quad cams which will pwn j00 liek dAt!!1!1!one!1!11
    I dont think anyone attempted it because its just too much power to contain in one engine. The slightest tuning mistake and the resulting explosion could be confused with a nuclear device and may trigger a retaliation repsonse to the enemy country du jour.
    The IN thing now is to do Quad VTEC DOHC heads with Remote Trunk Mount Cylinders, turning that V8 into a 16 Cylinder Monster!
    3,316
    yea but hes looing for a TT setup, not a QT setup
  1. mach 1 motor vs cobra motor
    By 89stang in forum The Bar
    Last Post: 07-28-2011, 09:45 PM
  2. Replies: 0
    Last Post: 01-07-2009, 11:08 AM
  3. Lightning motor vs regular f150 motor
    By scott5 in forum S197
    Last Post: 08-18-2008, 03:15 PM
  4. Motor
    By 383taman in forum Ford Vehicles
    Last Post: 06-22-2007, 08:45 PM
  5. Anyone looking for a 5.0 motor??
    Last Post: 06-05-2007, 02:33 PM
