my buddy needs help with his AEM wideband gauge. the problem is he bought the gauge used and need a wiring diagram. anyone have any idea.
1988 GT "SVTGT" Terminator Fox![]()
2003 Cobra SVTGT donor. (sad bare chassis)
1990 LXC 4cyl. (turbo 2.3 in progress)
2004 World Rally Blue STI (Daily Driver)
1991 5.0 Auto Notch
1986 notch(retired SCCA car)
There should be two connectors, they wont interchange.
The one connector is for the sensor, its a complete harness, so you shouldnt need any connection ifnormation there. If its cut, match up the wires ;)
There should be 4 wires off the other connector
Red - Goes to 12V + fused
Black - Goes to good ground
White - this is the 0-5 VDC output, I use this to data log via my SSI-4
Blue - This is the serial output, if he is going to use this, he will need more information.
Basically to use it as a gauge, +12V to the red, Ground the black, and plug in the sensor harness :D
