Results 1 to 10 of 10
Thread: Throttle position sensor question
    I have a 90 bronco 2 with a 2.9 and I am going to be replacing the TPS soon. I know how to replace the sensor, but do I have to set it up? Like check the output or anything like that. If so does anyone know what it should be and how to adjust it?
    Thanks
    Chugger
    Havin A Ball... Screemin3o2's Avatar
    Virginia Beach
    110
    I'm not sure whether the tps on the broncos are adjustable or not. The voltage output should be around .98v
    -Jonny
    95 Mustang GT
    Slow Bolt On Car
    ModdedMustangs.com
    to replace it you just unscrew the 2 philips head screws and take it off and install the new one in its place, to set the tp-voltage, the black wire is the ground, the green is the sensing wire and the orange is the voltage input wire, hook up your multimeter (dc-volts) to the ground and the sensing wires then check to see if you have .98-1.00 volts its best to be at .99 volts, but sometimes you have to hog out the holes, now to check and see if you have a good senser hook up to it the same way i just told you to and use a graphing meter then push the throttle to the floor and the graph should go all the way to 5 volts and drop back down to .99 when you let off of the throttle, If you have no glitches in the graph line the sensor is good but if you have any glitches the senser is bad...or if the senser voltage is off the chart or like 2 volts at 3/4 throttle.
    Virginia Beach
    110
    doubt he has access to a scope
    -Jonny
    95 Mustang GT
    Slow Bolt On Car
    ModdedMustangs.com
    Quote Originally Posted by Screemin3o2 View Post
    He can just use an analog multi-meter.
    3,356
    Radio Shack sells digital ones starting around 10 bux or so. I still have my very first cheap one and it still works!
    Mark
    LeMans Blue Z06
    I actually loaned mine out a while ago and never got it back. I hate theives.
    Hey thanks, and I am getting my bachelors in HVAC so I do have a digital multimeter, and I may be able to get ahold of a scope.
    Quote Originally Posted by chugger95 View Post
    Not digital!! Analog. The kind with the arm that swipes from side to side.
    yeah but I don't have one of them here at school, I am probably just going to replace it with a new one anyways.
  1. Fox body speed sensor question
    Last Post: 06-03-2013, 10:55 PM
  2. throttle cable question
    Last Post: 03-26-2012, 10:05 PM
  3. Crank Position Sensor
    By RogerStout in forum General Tech
    Last Post: 02-14-2011, 09:49 AM
  4. How to convert an ABS sensor into a speedo sensor.
    Last Post: 01-27-2009, 11:46 PM
  5. throttle body question on 95 cobra
    By pimpincobra95 in forum Fox-SN95
    Last Post: 10-14-2008, 07:14 PM
