Results 1 to 5 of 5
Thread: tire hit launch pics
    track rat 04snake's Avatar
    Upstate NY
    136
    Not done yet but I am starting to understand how to handle hitting the tires real hard with a stick launching at the limiter. I am running 11.0, 11.1 more consistently with my eaton in hot air. Most 60 fts are around 1.52 - 1.56 with one 1.51, but I have to keep 12+lbs in the tires so I am always on the ragged edge of smoke'm them. Any lower and the Stiff side M/T slicks collapse bad, but if I prevent that they are hooking hard enough to pull the wheels a inch or so most passes with only 500 hp and almost full weight (3610 w/me).
    the first pics are if I cross the line of not enough air (11.5lbs) & too much rpm (6500) for my clutch, flywheel, 10x26" tire, air bags psi, combo.
    the second one is a real good hit on the tires, my best 60ft 1.51.
    now for my new recent pictures adjusting to track conditions and trying some other small tweaks. I have managed to keep from making them angry but if I miss the other way (too much air:spin or not enough rpm:bog ) I can end up with a 1.58-1.62 real easy, so by stiffening and focusing the 9" with the anti-roll, Mach1 springs and 5-to-20lbs in the air bags with a 5-7lb stagger I have a very small window of setup to get the most out of a tire that I can plant way too hard, way too easy!
    oh well the mushy IRS used to be much more very forgiving.
    nice to be back online, replacing the laptop that died during a pass 3 weeks ago (9/14) was a real PITA.
    Trying to get older software to run on vista sucks on top of all the $$$$!
    Who in the world gets all of these amazing shots of your car for you?
    Drop Kevin Slaby an email @ www.baselinesuspensions.com
    Im sure he'll be able to help you.
    Do you think there is too much separation between the driver's side rear slick and the bottom of the wheel well?
    Upstate NY
    136
    No but it is hard to get used to what a good launch should look like but the squat you usually see with these IRS cars is not what you want the rear suspension to do. Limited and very controlled suspension movement during weight transfer will usually give you the quickest 60fts. I am just running into a catch-22 with 26" tires. They are best suited for me gear wise thru the traps but after eliminating all the rear suspension deflection and switching to 26" slicks, screwed to the wheels, all of a sudden my tires can be overpowered with my measly 500 launch ponies. I need another 20-30 passes to get the combo better dialed in. Now all my passes are within 2 tenths, so I just need to find that higher level of consistency.
    Morgantown WV.
    563
    Wow! Those are some great pics.
    665/540 New times coming
  1. First try on launch control
    Last Post: 04-01-2012, 11:34 PM
  2. Megasquirt launch control
    Last Post: 09-26-2010, 12:09 PM
  3. MSD Launch Master 2-Step Launch controller
    By 01stanggt in forum SN95-New Edge
    Last Post: 12-23-2009, 02:24 PM
  4. Another wheels up street launch
    Last Post: 04-10-2007, 11:08 PM
  5. First launch of the year
    By Bluemeanietsi in forum Pictures & Videos
    Last Post: 03-23-2007, 02:48 PM
