Results 1 to 6 of 6
Thread: 5.0 Ho Short Block
    Member HOTMARK7's Avatar
    BUTLER PA
    148
    5.0 Ho Short Block
    Have My Short Block From My Mark 7 For Sale , Has Approx 7000 On Rebuild, New Timing Set, Crane Cam, High Volume Oil Pump, Main Stud Gurdle, Factory Forged Pistons, Resized Rods With Arp Bolts. Running About 7 Lb Boost And Just Bought An R Block And Going To Build Stroker, So Don't Need This One, Still In Car , Can Hear Run, Looking For Offers To Offset New Build, That Way Wife Is A Little Happier. Thanks, Ron 724-991-9084 Or 724-282-7734
    Petersburg,PA. 16669
    816
    what cam is it?
    how much you asking?
    88 GT...and some boost
    BUTLER PA
    148
    Crane CompuCam Camshafts
    Camshaft, Hydraulic Roller Tappet, Advertised Duration 262/ 270, Lift .530/ .530, Ford, Small Block, Each
    THE CAM # IS 444211
    I'm open to all reasonable offers
    816
    are you including timing cover,oil pan,lifters?
    BUTLER PA
    148
    I have another oil pan, if it is the same as the one on the engine, I'll leave the pan on the engine, other than that , it will have timing cover, dampner flex plate, lifters and spider, arp oil pump shaft. Also have stock HO cam for engine.
    BUTLER PA
    148
    up top
  1. 324 Boss Block Big Bore Stroker short block $2,900 O.B.O.
    Last Post: 05-03-2014, 04:19 AM
  2. Replies: 14
    Last Post: 02-22-2014, 01:52 PM
  3. WTB - Mild 331/347 short block or long block
    By PaceFever79 in forum Ford Parts
    Last Post: 07-11-2010, 07:05 PM
  4. 2v 4.6 short block
    By Black02GT in forum Ford Vehicles
    Last Post: 10-28-2009, 12:13 PM
  5. Fs: 5.0 Short Block
    By Rowleyxlt619 in forum Ford Vehicles
    Last Post: 10-29-2007, 05:11 PM
