Results 1 to 16 of 16
Thread: Phil's new Dyno results... With the 16V Volvo Head 2.3
    Leechburgistain Mainland,Cuba
    1,534
    Thumbs up Phil's new Dyno results... With the 16V Volvo Head 2.3
    "Phil just called me with the news of his Volvo head XR.
    His new recorded HP is 683HP/509TQ@ the wheels!! this was up till 7.5kRPM He was telling me that above that the wheels were spinning and started doing a burnout on the dyno! How freakin crazy! The Dyno guys were saying that he has (with traction) around 720HP. Phil's car is built to go to 9k RPM "
    289 slabside cobra
    6S1941
    WOW! Post up the dyno sheet if you can. I'd like to see what the curve looks like.
    1,534
    289 slabside cobra
    6S1941
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Map351,
    the link won't let you view without registering.
    How difficult is it to use a Volvo head on a 2.3?
    Mark Lowry
    Damn! The more I read these post about the little 2.3 that could, the more I regret not keeping my '91LX and doing the 2.3T swap I always wanted to do.
    803
    Thats awesome
    1,534
    Thumbs up
    Map351,
    register!
    When i built my Pinto it's set up for the Volvo swap..
    Everton Biggs in Florida made 962Hp with a 16V Volvo 2.3 engine. The head is the key to the Big #. There's a Volvo 16V head in the hands of IRL master head porter and the flow #s should be amazing!
    289 slabside cobra
    6S1941
    if some one comes out with a bolt on head kit for the volvo head i'll get one not even the intakes and stuff just a head that bolts on
    Just think how much power it would make with twice the cubes!!! cough*4.6*cough
    What's involved with putting the volvo head on?
    1,534
    That's easy and you can go to the Ford store and buy one.
    Here's the Yahoo group..It's not that big of a deal than it's made out to be..
    http://autos.groups.yahoo.com/group/2300-16V/
    "The head flows very well in stock form, I was impressed to say the least. ARCA competion, probably not ...but there is definitely some room for improvement. I hope to test the exhaust flow in the near future and I will post results from that too. The following tests were all intake flow comparisons. 1/2" radius was used and the cylinder wall shrouding was simulated with a 3.810" bore (.030" over bore.) 28" depression. I gave the volvo head the benefit of the doubt and centered it over the bore, but in reality it will not center on a 2.3 ford block. I doubt the shrouding is significant enough to disrupt flow in stock form though.
    The stock head was flown on cylinder #3. The ported iron head is one of my personal heads. It was maximized for a high lift high rpm application, and the low lift flow would have been slightly better with a port/valve combination optimized for low and mid lift flow. No epoxy or welding. It's close enough to give you an idea though....
    Here we go:
    Stock Iron D port/Boport Iron D port/Volvo 16V
    .050"_27.6___32.6____42.3
    .100"_56.8___64.2____85.1
    .150"_75.7___108.7___123.9
    .200"_98.7___142.7___164.1
    .250"_118.4__173.8___198.5
    .300"_131.0__193.3___219.2
    .350"_138.1__210.8___226.4
    .400"_145.3__225.7___229.6
    .450"_149.2__234.1___231.6
    .500"_153.1__238.7___234.1
    .550"_156.3__240.6___235.4*
    .600"_158.2__241.3___235.4
    .650"________242.6
    .700"________244.5
    .750"________245.2
    I will continue working on the 16V volvo and update with new flow findings in the future. In stock form I think it would be an excellent upgrade over a ported iron head. I assume maximum valve lift you could run would be .400-.450", even at that lift it is flowing a solid 230cfm. I will post ARCA intake flow in the near future as well.
    Bo"
    289 slabside cobra
    6S1941
    paul you have to add some material to the back of the volvo head and run some oil lines i think its just scary how close this thing is to being almost a bolt on
    Got Boost?
    West Mifflin
    1,442
    Very impressive.
    1994 Rio Red GT
    10.60 @122.88
    Sold
    Mt.Pleasant pa 15666
    2,832
    awesome
    I like hair dryers Twin01cobra's Avatar
    Wherever I want
    1,270
    Nice, maybe I'll cut my 4.6 in half and make two 2.3's with 2 turbos and make 1200+hp;) . Them little 2.3's are really impressive for sure.
    General Douglas McArthur
    LowHill
    2,679
    Thats awesome
  1. Volvo 16V head swap...
    By map351 in forum Fox-SN95
    Last Post: 11-13-2009, 01:06 PM
  2. dyno results
    By crazylou in forum Fox-SN95
    Last Post: 07-30-2009, 01:32 AM
  3. Replies: 29
    Last Post: 06-18-2008, 09:27 PM
  4. Dyno Test Results!!!!
    By mike5oh_93 in forum Pictures & Videos
    Last Post: 05-03-2008, 04:49 PM
  5. Dyno Results Are In
    By Rio94gt in forum Fox-SN95
    Last Post: 04-21-2008, 06:24 PM
