The Night Train has a rigid mount 1450cc Twin Cam 88B™ balanced engine that is black powder-coated with wrinkle black and texture black covers. It has a laced front wheel, disc rear wheel, Badlander seat, Drag bars, 6-inch straight handlebar risers, and blacked-out tank console, rear fender supports, air cleaner, and oil tank.
http://pittsburgh.craigslist.org/mcy/446089723.html
Engine:
Drivetrain:
- Type: Air-cooled Twin Cam 88B™ (balanced) V-Twin
- Displacement: 1450cc(88ci)
- Bore and Stroke: 95.18 mm X 101.52 mm
- Fuel System: Carburetor or Electronic Sequential Port Fuel Injection (ESPFI)
- Compression Ratio: 8.9:1
- MPG: 50 hwy / 44 city (42 for carburetor)
Upgrades:
- Transmission: 5-speed
- Final Drive: belt
Call For Questions: Chris Weck (412)651-3382
- Chrome shorty slash cut exhaust
- Dynojet Power commander computer
- Allows fine-tuning of your fuel-injected Harley-Davidson when changing air cleaner pipes and cams
- Each Power Commander unit comes with a built in microprocessor and Is supplied with a specific map designed to improve performance over stock
- A software package and computer link cable which allows you to fully map the fuel and Ignition curve is also included (requires Windows@ 95/98/2000)
- A power programming module is required to supply voltage to your Power Commander when removed from the bike and attached to your PC (must be purchase separately, not required If module is installed on bike)
- Dynojet Is continuously mapping different combinations for each bike; special maps can be downloaded at Dynojet's web site (www.powercommander.com)
- If you do not have a computer, you can change the settings with three touch buttons on the faceplate
- No wiring modifications are required; OEM-style connectors are supplied
- Chrome Hand Grips
- Chrome Foot pegs and Forward Controls
