i just finshed up my new rotated intake here is a bad pic![]()
What is the most difficult part of that mod there?
Making sure that you can still go around the alternator without moving it. You don't want to re-cut the upper apart to re-weld it back together at a different angle. Sometimes people don't get it right the first time.
Looks good !
The hardest part would be cutting the upper, and then determining how far to rotate it. Then, gutting the upper and port matching it to the new rotated base. Finally, lengthening the TPS and idle air control wires and connecting up the new inner cooler pipe. I hope to gain throttle response and better top end charge from the new intake mods. It is also set up to replace the tiny 50 mm tb. with the 60 mm off my yellow car.
Look's great Troy! Another step done
Joe- You should know, its all about small details. The problem is us 2.3 guys cant "buy" these little details, so we need to make them :D
thanks guys,
well after drivin the car a little bit yesterday, it spools up much quicker, and pulls good up top, i had a problem with the tb gasket and had to replace it, and the dip stcik wasn't fully seated and caused a mess underneath , its all fixed now and i hope to have vid of it later today,
troy
Looks good Troy, I had mine out today alittle and the PCV came out and made a mess too.
Looks good Troy. I should have taken a better pic tonight at the cruise-in but I never thought about it.
Awrite Troy! Some zing to go with the bling. Keep this up and it'll outrun a Slobalt. :)
Alicia*
www.mikeymustang.com
waiting on paul to post it we made one the other day .
Troy, which video are you refering to? i didn't get any video of your car, only a few pics.
THE IN CAR ONE![]()
we were taping the whole time from the pic spot to the cruise in .![]()
