Results 1 to 20 of 24
Thread: oil consumption problem???
    do you 4v guys and 2v guys have any problems with oil consumption??? i have a customer with a 96 4v and he claims it usees 1-1.5 qts oil between oil changes, he was using synthetic and it used 2-2.5 qts, then i had him change to castrol gtx and it reduced the consumption.. and this cas has NO leaks what so ever?? any input is appreciated.. approx 25k miles
    shaler,pa
    1,010
    Call Bob at ICS he has had a motor out of a cobra that drank oil. (412)366-1009
    89 Mustang (stock) DD
    82 Trans Am (not stock)
    98 Audi A4 (not so hurting)
    Power Adder
    236
    No never had any problems with my 2000 GT. It's like half a quart if that every oil change. I'd look and check out the PCV setup. I'd say maybe valve seals, but with the low milage I doubt it....hmm you have a good puzzle on your hands.
    Chris Kauffman
    1988 408LX drag car
    what kind of headers on it?
    bbk???
    Somerset Co.
    2,907
    My car has 17,000 on it and I havent added any oil to it besides regular oil changes.
    4,321
    mac long tubes are notorious for causing that. my 03 gt with 2k miles burned oil like it was cool after the mac lt install, you should have seen it smoke out the dyno bays at kauffmans and stropes
    My 2000 Gt when I had it used 1.5 qts just going to Bradenton from Cranberry. About 1400 miles.
    My 2004 GT seems to use a little oil but has no leaks and doesn't smoke that I have noticed. I run 5w20 Royal Purple. Course high rpm launches may be to blame as the cams whip the oil into a nice mist to get pulled into intake.
    Banned George C's Avatar
    1,490
    how do headers cause oil consumption?
    From my experiences with motors going thru that much oil. It could be several issues. could the the PCV system sucking in oil, or it could be a cracked ring gland. these are two common findings with the LSX community and im sure its the same for a Mod motor
    Senior Member stieny's Avatar
    Pittsburgh
    1,392
    From what I've heard, because of Mac's poor build quility, the slag inside the header from the poor welds were getting sucked back into the motor and scoring the cylinder walls causing bad blow by.
    '15 CLA250 4Matic / AMG Sport
    1,490
    Quote Originally Posted by stieny View Post
    thats the first i heard that. if thats the case then wouldnt that be in the installer? I mean I dont install a part and not inspect it before installing. and if it is scoring the motor then i would file a lawsuit against Mac. Now if it did score the walls then you need to rebuild motor.
    My 2000 GT ate qt every 3k. My 99 Crown Vic P71 (was non PI) DRANK OIL LIKE MAD. 1.5 every 3K like nothing. Not sure why. My Push rod motors dont use oil. Guess I will see what the Linclon does.
    this is a mystery to me, i rebuilt this engine 25k ago, from top to bottom, it has no leaks at all and blows no smoke, but it still eats 1-1.5qts between changes. i have ben told by some people that there cars just use oil, my 5.4l truck eats a qt between changes but it has 180k on it..
    1,490
    the oil ring might of took a shit, could possibly have a bad ring seat, could be the pcv sucking in oil. its smoking but not where you notice it. a motor doesnt go thru oil and dont smoke. noticed with the LSX family under WOT it sucks oil thru the PCV but its hardly noticable if any notice. but they still go thru oil every oil change period
    3,356
    The older type Mac headers had weld slag down in them and they caused many a bad motor.
    They have since fixed the problem with the newer sets.
    No fault of the installer IMO. Do you extrude hone all of the new long tube headers that you install? That's the only way I can see to know that all slag is out since you can't see all the way down the tubes.
    Mark
    LeMans Blue Z06
    1,490
    headers man i never heard that. and for it to suck passed the exhaust valve and not affect how the valve seals to teh seat...I just dont see the slag doing it but if it did thats interesting and I dont think Mac would be in buisness if this was the case. The case is the motor is consuming oil, so it either has blowby or poor crankcase ventalition.
    This was happening to a few people and was discussed in length on the corral. MAC was aware of the mishap and claimed they rectified the issue.
    1,490
    but isnt not hte case in this one. as he stated bbk headers i do believe
    Drop a pushrod mill in it and be done.
    1,490
    have to agree with ya on that one
  1. Replies: 7
    Last Post: 05-01-2010, 07:59 PM
  2. Little problem
    By 383taman in forum Pictures & Videos
    Last Post: 08-20-2009, 12:22 AM
  3. Oil problem Need engine manuals
    By jaa55 in forum SN95-New Edge
    Last Post: 06-26-2009, 08:36 AM
  4. Another problem
    By Balaska347 in forum General Tech
    Last Post: 09-02-2007, 09:35 PM
  5. HP problem
    By Carbed89Lx in forum General Tech
    Last Post: 05-16-2007, 11:30 PM
