Results 1 to 10 of 10
Thread: Need some input
    Stangin' Stangin's Avatar
    N. Versailles - 15137
    168
    Need some input
    Ok, I finally break down and get a set of wheels that look good on the car and when I get to mounting the last one, I realize, hidden beneath a wheel weight, a rather large HOLE in the rim. It doesn't appear as big in the pic as it actually is.
    Now I partly blame myself for not looking a bit more closely, but at the same time, I see this as something that should have been brought to my attention. At the moment the wheel/tire still holds air, but when the tire is due to be replaced, the weight will have to be removed. Which is how I believe it got this way in the first place. I am concerned of the safety aspect as well. There is another wheel with a small segment missing which may have occurred the same way.
    Is there any way to correct this, or do I need to start searching for a matching replacement, or 2?
    Thanks for your input.
    Jim
    Stangin'
    94 GT Convertible, 5 Speed ( '07- '?? )
    90 GT ( '93-'07 - 14 Years - 250,000+ miles "The 1/4 Million Mile Stallion" ) *SOLD*
    84 Convertible, 3.8, Automatic ( '97-'99 )
    Mt Pleasant
    2,916
    you can get it welded but you can pick up another rim like that pretty cheap though. it should be ok but i still woudnt trust it 100%
    Chandler, AZ
    1,532
    Don't trust it...buy a replacement. The tire is seated on the rim approx 1/2 - 3/4" below the crack in the rim. Hit a pot hole or a bump right and there goes your air pressure.
    168
    Quote Originally Posted by SV1000s View Post
    That is exactly what I was thinking. And driving around in the "Pothole Capitol of the World" certainly doesn't ease my mind any more. I've already taken them off and went back to the Tri-Bars. If I can come across a couple more I will probably grab them.
    Stangin'
    Farmington WV
    4,672
    silvernotch on her has a set he is selling
    5 Lug?
    168
    5 Lug?
    Yes 5 lug, they are Ford factory 96-98 GT wheels. But he no longer has them, I do.
    Stangin'
    Quote Originally Posted by Stangin View Post
    Not you, I quoted jared.
    i can weld that with no problem and make it look like it was never there.. just gimmi a call.
    168
    Thanks Tim,
    I'm not too sure what I'm gonna do at this point. I may just sell these and try to break even and find a different set. I just put 4 brand new tires on the Tri-Bars so I'm ok for now.
    I'm gonna need to replace my clutch soon too so that may end up being a priority.
    Thanks again,
    Jim
    Stangin'
  1. Looking for pistol input ...
    By mr4teth in forum The Bar
    Last Post: 05-13-2012, 11:12 PM
  2. Input shaft question
    By yellowstang03 in forum General Tech
    Last Post: 09-21-2010, 06:36 PM
  3. Exhaust Input
    By Shanehead89 in forum General Tech
    Last Post: 06-11-2009, 03:25 PM
  4. Gears!! I need some input.....
    By Stangin in forum General Tech
    Last Post: 07-28-2007, 10:33 PM
  5. Input on this 302 out of the '84
    By Ares in forum Fox-SN95
    Last Post: 05-28-2007, 09:55 AM
