Results 1 to 17 of 17
Thread: Firewall Adjusters??
Hybrid View
    Stangin' Stangin's Avatar
    N. Versailles - 15137
    168
    Question Firewall Adjusters??
    I am going to be replacing the clutch soon and am looking to go with an adjustable cable/quadrant & Ford Racing or King Cobra kit. And I need to know how reliable the firewall adjusters are. I always had the advantage of putting the '90 up in the air to make adjustments. No longer have access to a lift, so I'm wondering do they work? Do they back off on their own? Or should I just stay away from them? Pros/Cons
    Thanks
    Stangin'
    94 GT Convertible, 5 Speed ( '07- '?? )
    90 GT ( '93-'07 - 14 Years - 250,000+ miles "The 1/4 Million Mile Stallion" ) *SOLD*
    84 Convertible, 3.8, Automatic ( '97-'99 )
    I have used them before and I have had instances where it would back off on it's own. I'm still a fan of just using the adjustable cable instead. Only diference is like you said, you have to get under the car to adjust it.
    168
    Yeah, that's kinda what I thought. In most cases, once you get it set the way you want it on the bottom, there really isn't much need to adjust any further. And a decent set of ramps should be adequate to get to the cable from the ground.
    Thanks Ed, I knew someone out there had some experience with them.
    Jim
    Stangin'
    Quote Originally Posted by Stangin View Post
    My feeling exactly. I know that I will not spend money to ever buy another.
    Mt Pleasant
    2,916
    ive had them on all my cars and never had any problems with them backin off. i put one on every car i get.
    4,321
    Thanks
    keep your stock cable and if it needs replaced make sure you put another stocker back in there...you don't want or need an adjustable cable. i have used many different firewall adjusters over the years, i didn't like any of them until the fiore piece which is no longer made to my knowledge. here is a new and great option...http://www.uprproducts.com/shopping/shopexd.asp?id=1040
    i am not a fan of upr but this is a pretty sweet piece and i have installed several of these...lou stocks these at LMM. as far as the quadrant goes there are plenty to pick from, how you use and drive your car should be the deciding factor...good luck either way
    Mike, just curious why you feel this way. I have adjustable cables on both of my cars and I really like them. I don't think firewall adjusters were even available back when I put the adjustable cable on the 85 and I didn't go with the firewall adjuster on the cobra because I didn't want to deal with the clearance issues around the cam cover.
    4,321
    Ray,
    i have seen and heard of way to many failures to give them a shot or recommend them to anyone. the stock cables seem to be stronger and stand up to the abuse much better so i have always stayed away from them. im sure someone has broken a stock cable but i don't know anybody who has, i've put them through some serious abuse with aggressive quadrants and have never had one fail or damage.
    Mike
    I've used both the stock and adjustable cables. Never had an issue with either one breaking other than having a few seize up from too much heat around the headers, but that's no fault of either type of cable.
    3,356
    The Fiore adjuster is what I run. I like them since they have the little detent ball that sits in the groove to keep it from moving on you.
    The Steeda, UPR, and Fiore quads are all good. Some have a faster ramp profile as well.
    I just use the stock cable.
    Mark
    LeMans Blue Z06
    4,321
    im sure on a street car, less the power shifting...it will stay together. for aggressive street driving, aggressive quadrants, track abuse etc...i just felt like if it wasn't broke don't fix it after all the broken aftermarket cables!!!
    Ray,
    Mike
    Fair enough. I've seen both stock and aftermarket ones break, but would also tend to believe the stockers are probably a little stronger in most cases. I had the stock one on my 85 go bad, but like Ed said, that was just due to header heat and not the cable itself actually breaking.
    FYI - I have a UPR tripple hook quadrant and firewall adjuster I bought off someone here for sale. The quadrant looks to be new, the adjuster looks a little used. I'm not using them, I think I have $35.00 in it.
  1. Headlight adjusters 94-98
    Last Post: 03-13-2012, 08:02 PM
  2. Clutch quadrant and firewall adjuster???
    Last Post: 07-07-2011, 08:45 PM
  3. Wtb... Fox fr. Cut firewall up
    By crazylou in forum Ford Parts
    Last Post: 11-25-2010, 08:35 PM
  4. WTB: 03-04 cobra firewall plastic
    By RUTHLESS in forum Ford Parts
    Last Post: 05-26-2009, 07:53 PM
  5. Firewall clutch cable adj
    Last Post: 03-16-2008, 06:50 PM
