Results 1 to 20 of 27
Thread: Fox Hooker Long Tubes on SN-95
    North Hills of Pittsburgh
    430
    I'm attempting to install the 6222 headers on my '94 Cobra. The passenger side fits perfectly and even clears my Mcleod safety bellhousing. Three of the four primary tubes separate and make installation and starter access very easy. The driver's side is a bit challenging since the one tube is rusted/seized together. If I can get it apart, I think I can install the header without unbolting the steering shaft. I will let everyone know how it goes.
    2016 GT Premium
    Bridgeville
    1,278
    i just got hookers on sounds amazing those hookers looked like they have seen better days ur putting on,
    I see that the headers were set up for a crank case evac system (check valve probe in collectors) and that the O2 sensor bung is located in one of the primaries vs. the typical placement in the collectors. I wonder if it effects the accuracy of the A/F since it samples only 1 cylinders exhaust instead of a combination of the 4 on one bank??
    Good luck on the rest of the install!
    430
    These headers have seen better days. If they fit, then I will sandblast them and repaint them with VHT. I took a chance on them for $200, which included the matching Hooker H pipe. I was wondering that myself about the O2 only sampling one cylinder. I guess if all four cylinders are the same, then it "shouldn't" matter. The guy I bought them from ran them this way on a '89 5.0 for 5 years without problems. He also had them on a race car for a while, which is why they have the evac mods.
    2016 GT Premium
    are those 1.3/4" tubes??
    430
    They are 1 5/8" and a true 3 inch race collector. All tubes are equal length.
    2016 GT Premium
    Ohh, I thought they were 1 3/4 also.
    I just picked up a set of Mac Ceramic coated 94-95 Mustang 1 3/4" Headers
    w/ 3" collectors in Mint condition for my ride.
    430
    Nice find gmkillr. Those should help you a lot.
    2016 GT Premium
    I think so too!
    Now I just need to get a Dr. Gas 3" X-pipe and some 3" Ultraflow's to dumps!
    I think so too!
    come on.....don't be scared... go with the dynamax bullets.
    I might!
    430
    Hit a brick wall with my install. The number 8 primary tube is rusted/seized and it will not separate without destroying the headers. I tried a torch, PB Blaster, liquid penentrant and spent 4 hours trying to separate it. I am returning the headers and getting my money back. It does "look" like these 6222's would have fit my sn-95. I know for sure the passenger side fits.
    2016 GT Premium
    That sucks! Sorry to hear your haing such a hard time.
    430
    I was able to finally separate the seized primary tube using an acetelyne torch. Once properly heated, they came right apart very easily. I then fitted them up and they fit my 94 cobra with the Energy Suspension motor and trans. mounts perfectly. The driver's side even clears the Mcleod bellhousing without any grinding needed. No need to even jack up the motor since the tubes are removable.
    2016 GT Premium
    Watch those Energy Suspension engine mounts man. They dented my old MAC 1 5/8" longtubes. They allowed more movement than the stockers. Believe it or not. Now that's with a semi-aggressive leave.:o I've since switched to solid's out of the LMM camp.
    Glad to hear you got it done!
    Whats next?
    430
    I found an AFM B41 used cam for $125. That will be going in this winter. Rick A. told me that cam would be perfect for my goals. Pulling the engine and tranny in the next few weeks. Tranny is going to Hoss' gear shop for new synchros. Rehone and rering for my 347. I wanted to fit the headers before removing the engine and tranny to make sure they fit. Now, I will strip and repaint the headers.
    2016 GT Premium
    Way to go Bob!!!!
    I knew if you kept with it you'd get that F$#%#*g header apart!! Maybe the Kroil had a little to do with your eventual success?!?! I can't wait to hear what that beast sounds like once you have it all back together with thsoe headers on & the new cam in there.
    Heading out to the garage now to get a little work done on the GT.
    Congrats again!!
    Make sure you use the correct springs for it.
  1. Fox Long Tubes - Steering arm
    By coralcoupe1993 in forum General Tech
    Last Post: 10-12-2008, 11:41 AM
  2. H Pipe Long Tubes Fox
    Last Post: 08-20-2008, 07:49 PM
  3. Header Match Fox Long Tubes.
    Last Post: 07-21-2008, 01:55 PM
  4. Fox Long Tubes
    Last Post: 07-20-2008, 03:13 PM
  5. Just bought some used Hooker 6222 long tubes
    By 94Cobra in forum Fox-SN95
    Last Post: 10-10-2007, 03:44 PM
