Thread: 91 351w bored .030 over 10.5:1 compression
    Yellow is faster!
    York PA
    273
    1991 351w seasoned block
    bored .030 over honed and decked
    Flat top pistons floated on stock rods 10.5:1 compression
    Standard volume oil pump
    Fox mustang oil pan and pickup
    Sealed Power high performance low drag rings
    Edlebrock Victor Jr. cylinder heads 2.05/1.60
    Crane Cams 1.6 aluminum roller rockers 7/16" stud mount
    Comp Cams Hydraulic roller cam 304HR 576/576 304/304
    Trick Flow pushrods custom length
    Edlebrock Victor Jr. Intake
    Holley 750 double pumper mechanical secondary carb
    MSD billet distributor specifically designed for Victor Jr. Intake
    New water pump
    This is a drop in piece. Hook up fuel and ignition and you are ready to run.
    3200 miles on this very strong running motor!
    $3500 ... will take parts off if adequate payment is made for either longblock or shortblock.
    This motor is still in the car. Please come listen and drive it.
    Thanks
    http://www.98yellowstang.com/Trashy%20reborn.mpg
    Yellow is faster!
    York PA
    273
    $3250
    Jason
    Just a little stock coyote that runs low 10s!
    Senior Member SV1000s's Avatar
    Chandler, AZ
    1,532
    what kind of power is this mill putting out?
    Yellow is faster!
    York PA
    273
    I would hope at least 350 rwhp, never been on the dyno with it. It did go 110 MPH granny shifting on a stock t-5. Probably good for 115-117 MPH in a 3100 lb car and proper shifting.
    Jason
  1. F/S .030 over boost engine
    By TooFast98Cobra in forum Ford Vehicles
    Last Post: 11-23-2011, 10:17 AM
  2. WTB:351w 4.030" forged pistons
    By 1badnotch in forum Ford Parts
    Last Post: 11-17-2010, 08:38 PM
  3. WTB .030 Pistons
    By gyides24 in forum Ford Parts
    Last Post: 03-17-2010, 11:11 AM
  4. im bored is anyone else ?
    By alexstang07 in forum Meets & Events
    Last Post: 09-17-2009, 10:59 AM
  5. 302 roller block .030
    By 349Stroker in forum Ford Vehicles
    Last Post: 07-26-2009, 11:27 AM
