Going to mix up some of Loki's "Boo Juice" (as we're apparently calling it this year)
It holds about 4 gallons in its current configuration, In the future i'm going to upgrade to 9 pumpkins and allow for 3 different drinks/punches with some other aesthetics. Right now it just lights up and is pretty crude, we needed it for tomorrow so I put this together last night. I might paint it up a little bit too.
If you're interested in doing this you'll need, everything but the spout is from Walmart, the spout is from a local supply store.
3 packages of plastic weld epoxy - $7.00
3 pumpkin pales - $3.00
1 plastic spout - $4.00
1 plastic spout adapter - $1.00
1 plastic heavy duty plate for base - $3.00
For the lighting I just basically slid a large "shot" glass I found for $1 in the craft section of walmart into the center pumpkin (which would work better in the bottom one but too late) and added a christmas fake candle light $1 to sit inside it.
So for $20 I have a 4 gallon conversation piece that next year is going to be a lot cooler and I plan on painting it up a little better. Once you sand the plastic pieces down and epoxy them they're sturdy as hell I can sit on it.
Next time I might put this up through the bottom instead but here's the part for the light.
