Results 1 to 4 of 4
Thread: Meth Injection a N/A
    California, PA
    31
    i asked this question on modularfords.com, which i hate by the way, but would it be advantagious to install a meth injection kit on a N/A car? I would like to put one on my mach but i didn't know if it was worth. Snow performance makes a kit for N/A cars. So?
    2.4 KB & Juice
    Export, PA
    844
    Don't know alot about it, but I've only seen it make big increases from non-intercooled cars.....for what the kit cost, why not try it and see the results..doesn't hurt!
    07 Silverado
    05 R6
    Pure Stock will be the one to chime in on a N/A combo.
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    I would think you would see little benfit unless you had a high compression motor or were limited to 91 or 87 octane on a race type motor. Most of the cars use it to lower air inlet temps due to the heat of compression caused by the blowers or turbos. If you have pinging issue it may help. I would not expect any great HP gains like the boosted cars can achieve with additional timing run with lower air charge temps.
    Mark Lowry
  1. Coolingmist meth/alcohol injection setup
    Last Post: 11-15-2012, 07:09 PM
  2. aftercooler or snow meth kit?
    By 1badnotch in forum SN95-New Edge
    Last Post: 07-20-2011, 07:51 PM
  3. SCT MAF in a 3" pipe and meth injection?
    Last Post: 04-02-2011, 03:57 PM
  4. 2.3 Dyno + Meth injection
    Last Post: 02-25-2010, 05:26 PM
  5. WTB Water/meth injection kit.
    By John4cam in forum Ford Parts
    Last Post: 10-31-2009, 12:47 PM
