Results 21 to 40 of 49
Thread: No Spark!!!!
  1. #21
    Mt Pleasant
    2,916
    Listen, take the dist out of the engine, leave it plugged in, then either use a jumper wire to go from the dist to the block or you can try to hold it up against something for a ground... leave the key on and unplug the coil wire from the coil and simply turn the dist gear, you should have spark jumping from the coil, if that doenst work try unplugging the spout, then turn the gear... I have seen one of the 3 power wires going to the ecu not working correctly (usually a fuseable link), taking out the spout and trying it helps use 2 diff "parts" of the ecu...
    ok. i did what you said and i have spark jumping from the coil with the spout in and out.
  2. #22
    then you should have spark eith the dist in place, now you know that the dist/pick up/module are working, check the coil wire and verify that the dist is spinning when the motor is turning over, if it is turning check to be sure the rotor isnt broke, then put the cap back on and check for spark again..I would have to say, if you still have no spark, I would suspect a bad cap or wires...
  3. #23
    Mt Pleasant
    2,916
    ok after messing with this thing for hours and days, i finally noticed that the rotor was not spinning. i then assumed that the starter wasnt engaging so i looked down to see if the crank was spinning and it was so at this point i figured the timing chain was broke or something so i took off the waterpump and timing chain to discover there was no key in the crank. so all this time thats why it wasnt getting spark because without the key of course it wouldnt spin the cam to make the dizzy turn to make spark. now i have a new problem. im getting spark now and fuel and still no start. the car did set for two years but i replaced the plugs,rotor,cap,dizzy,plug wires,and coil. any suggestions?
  4. #24
    I'm going to guess at this point it is just nowhere in time. Bring #1 to TDC and set the distributor assuming you did set the cam with the crank after putting the key in it. If it's poping like it may want to start you may have it 180 degree out. Also verify you have the firing order set correctly since you changed the wires.
  5. #25
    you prob fouled all the plug by soaking them with fuel while trying to start it, a soaked plug may fire out of the car but not under compression, and yes Ed is right when you put the dist back in you will need to set it back in time, you can't just put it back in any old way..
  6. #26
    Aren't those interference motors?
  7. #27
    I was gonna say that the dist was not turning by cause of a missing or sheared key. I just did not want to look dumb. I am sure it is way out of time. TDC it and re-do the dist timing. It should be allright.
  8. #28
    Mt Pleasant
    2,916
    i did put new plugs in and still nothing. i did line up the dots on the timing chain when i put it back together. there is something really weird going on though. i pulled #1 plug out and did the til your finger pops off method but it wont do this. i dont get it. then the last time i pulled the dizzy out to move it, the oil pump shaft came out with it. i cant win with this car,
  9. #29
    It might have interfered and bent a valve as bob said. I cant understand how a pump shaft can come out. Rush on here had the same problem. It is supposed to have a clip to keep it in. It only comes out from the bottom after taking the pump off.
  10. #30
    Are positive the timing marks are right? Forget the dizzy for now, but crank to cam timing right? If so, I suspect you have a bigger problem. You said the crank was spinning, but the dizzy not turning. Well, the pistons where going up and down, and the valves where stationary :( I hope i'm wrong, but.......
  11. #31
    Unfortunatly this is probably the issue.
  12. #32
    those retainers fall off really easy...and yeah, it sounds like you bent some valves...
  13. #33
    That sucks. So, in that case, there is also a metal retainer floating around the oil pan too.
  14. #34
    Mt Pleasant
    2,916
    so what should i do next? would a compression test tell me anything or should i just tear the heads off?
  15. #35
    I would just pull the heads. It takes nothing to do so. If you need valves, we all have some.I have a whole set here you can have.
  16. #36
    Mt Pleasant
    2,916
    alright man, thanks!! ill let you guys know what happens
  17. #37
    I have a complete longblock I'd like to get out of the garage. PM me if you're interested.
  18. #38
    Mt Pleasant
    2,916
    the bottom end is fine im sure. its got to be something with the valves so im just gonna tear the heads off and get em fixed. thanks anyway
  19. #39
    Mt Pleasant
    2,916
    well...i took the heads off today and i got 8 bent pushrods and 8 bent valves but i also got to learn a little bit about the botton end. its .040 over and has forged speed pro pistons.
  20. #40
    SO what are your plans gonna be? A nice set of TW's or re-build the stockers?
  1. 5.0 loosing spark
    By 1natehanson in forum Fox-SN95
    Last Post: 09-12-2010, 05:31 PM
  2. 95 5.0 no spark no fuel
    By 95gts in forum Fox-SN95
    Last Post: 04-11-2010, 07:07 PM
  3. 95 GT with No Spark
    By real_jeff in forum Fox-SN95
    Last Post: 12-27-2009, 01:17 PM
  4. No spark
    By blkp42e in forum Fox-SN95
    Last Post: 08-13-2008, 01:29 PM
  5. Spark Plugs
    Last Post: 07-28-2008, 06:53 PM
