anyone know the location of a fox bodys horn relay?
i looked in my shitty chiltons and don't see anything in the electrical diagrams
thanks
thanks
Good question Russ. For some reason I want to say it's under the dash above the fuse box. Never had to find it before. There's only a few relay's under the dash, so it shouldn't be hard to narrow down. Just trace it from the trigger wire in the column.
The horn relay is located on the driver's side under dash you will see a small
white sometimes yellow relay when you unplug it you will see it has 3 terminals
On my 84, its behind the panel on the passenger side of the dash. I would suspect that changed at some point through the variations.
1988, i found 2 relays side by side next to the chiming box under dash next to console.
one relay has three prongs-other has 4 or 5
