Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: 1966 Galaxie Under the Knife!
  1. #21
    Quote Originally Posted by cobra232 View Post
    well if it's original it's a 428.
    410's were merc only.
    damn nice project car BTW.
    ever though of a steep geared high revving FE??
    360/390 block or 359 FT block with 359FT steel crank/rods/balancer/flywheel.
    ported edelbrock heads/harland sharp rockers/nice big cam topped with a dual quad offy intake and Carter/edelbrock 600's???
    put some 4.56 gears in it and it will scream like a 427.
    although i do love the 410 and 428 they have diesel torque
    Thanks man! This car is on its 3rd motor. It has been from Canada to Florida and all in between. Started life as a 240 inline 6. Then I put a beat up 390 C-6 in it. Then I put a fresh 410 in it. (390 with a 428 crank used in mercs) with a built C-6.
    This car is staying mild. I put the performance stuff on my 64 Galaxie (390/417ci), Edelebrock aluminum heads, Shelby roller rockers, Tri-power.
  2. #22
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Here's just the thing for your Galaxie!
    http://www.survivalmotorsports.com/FE-Engine-Kits.html
    Prison Break 445 - 390 FE Stroker Kit
    The best way to get big power from your 390! Scat 9000 series ductile iron stroker crankshaft Your choice of Probe pistons - dished for 9.8:1 compression with 72cc heads or flat tops - 10.8: compression (Both only available in 4.080 bore - .030 over), Scat 6.700 I beam rods with ARP 8740 bolts, Moly rings, Main and rod bearings, Internally balanced - use your stock flexplate or flywheel
    Mark Lowry
  3. #23
    Brookline
    2,897
    Nice ride to work with... the house in the background of the one pic looks pretty sweet.
  4. #24
    I just got a Tremec for the 64. Depending on how it runs, I may do somthing else with that motor!
  1. 1966 Galaxie with 429 CJ - $7500
    By PaceFever79 in forum The Bar
    Last Post: 06-03-2011, 10:39 AM
  2. Nice knife found at carlisle
    By Rodeheaver's in forum The Bar
    Last Post: 06-08-2009, 02:43 PM
  3. 1966 Galaxie 500 XL $1200
    Last Post: 05-27-2009, 05:20 PM
  4. 1966 Galaxie 500 Vert
    Last Post: 07-15-2008, 11:29 PM
  5. Sonic 03snake under the knife
    By Sonic03snake in forum General Tech
    Last Post: 05-01-2007, 08:56 AM
