Page 4 of 4 FirstFirst ... 234
Results 61 to 79 of 79
Thread: Question on 94-95 Mods
  1. #61
    1,171
    well thats ugly
  2. #62
    Are those stock puchrods?
    I believe your suppose to run hardened pushrods when you run aftermarket cams. They are probbly also the wrong length if they are stock. Your going to have to measure & see what length your going to need. You will need an adjustable pushrod to check for the correct length. Im sure someone w/ alot more knowledge will chime in. Good luck!
  3. #63
    803
    That sucks dude.
  4. #64
  5. #65
    Looks like it's time for some new pushrods and some roller rockers. At least it wasn't anything too serious though and you don't have to tear the whole engine apart again.
  6. #66
    2,103
    Small update, took the rest of the pushrods out of the passenger side head, and all are bent. I would assume they are all bent on the drivers side too, but I havent taken off the upper intake yet to get to it. Yay. I can't wait to do all of this in the driveway. My dad doesnt know what hes going to do yet. And I have no suggestions, other than to not spend any more money on the stock heads. Anyone else?
    03 Cobra=slow show car...
    13 F-150 Limited
  7. #67
    2,103
    Back from the dead yaaa. OK finally took the other valve cover off and yes I was correct all are bent on the drivers side too durr. But anyway, we were expecting that, not to find that some of the springs had also broke. Soooo, heads are coming off. They will not be going back on. Any suggestions for a set of heads for this car? Any for sale? Voice your opinions on heads like you all havent done that before!
    13 F-150 Limited
  8. #68
    Slap a set of Trick Flow Twisted Wedge heads on there and call it a day. Put a set on my 90 and it picked up over 70 rwhp over the Iron GT-40's that were on it with running less timing and 2# less boost.
  9. #69
    And the E-cam helped a little too.
  10. #70
    E, F, G, what's the difference?
  11. #71
    Peak power checked in at, let me guess, 5,600 rpm??
  12. #72
    No idea. I never looked at the chart.
  13. #73
    AFR165's would be my choice, especially in that heavy car.
  14. #74
    More cubes would be my choice, via a 9.5" deck.
  15. #75
    2,103
    Over a year later....the AFR 165's came today! Guess I need to start taking it all back apart again!
    13 F-150 Limited
  16. #76
    Nice! What cam are you going to run?
  17. #77
    2,103
    comp cams extreme energy XE270HR-14
    Specs on cam:
    Intake Duration at 050 inch Lift: 218
    Exhaust Duration at 050 inch Lift: 224
    Intake Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
    Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
    Lobe Separation (degrees): 114
    Same one that was in it before. Will that be alright with those heads?
    13 F-150 Limited
  18. #78
    wow, i cant believe i missed this thread for over 3 yrs.. But im also kinda curious what kinda of gains you get with those 165s.. I am thinking of throwing those on until i get my other motor done.. Steve did you check into the anderson ford cams?
  19. #79
    p/n B-21
    Same as B-31 except utilizing 1.7 R.R. N2O or S/C 8-15 lb 302 c.i.d. Best performer for 1.7 R.R., stock pistons and 6200 rpm. Great with TFS or Edelbrock heads. Minimum 30lb injectors and 80mm mass air. Recommend 3.55 or 3.73 gears. Good drivability down to 1900 rpm, mild idle, rpm range 2400-6200, works best with 89-93 EEC, needs 2600-3000 converter. Great N.A. cam for 94-95 Mustang with great drivability. With bolt-down R.R., needs 0.040" longer push rods.
  1. 04 mods
    By thaley21 in forum Fox-SN95
    Last Post: 04-13-2011, 05:44 PM
  2. some new mods....
    By yellowstang03 in forum Pictures & Videos
    Last Post: 08-04-2008, 09:07 PM
  3. first mods
    By Jper in forum General Tech
    Last Post: 05-05-2008, 05:00 PM
  4. New Mods!
    By no1fordgirl in forum Pictures & Videos
    Last Post: 03-23-2008, 08:58 PM
  5. new mods
    Last Post: 10-22-2006, 02:48 PM
