Im sellin my motor out of my car these are the specs motor has maybe 300 miles on it the motor is still in the car so if you are interested i will take you for a ride i need to get 4500 for motor i have over 6500 invested
Eagle competition rotating assembly
Forged Crank
Forged H beams
Srp .040 pistons
Compression is 10.5
Assembly was proffesionaly 0 balanced
pistons and rods are all within a tenth of a gram
Done by Paul Rodlands machine shop
1974 351w block
All machine work was done with tourqe plates and girdle installed
line honed, bored.040, new cam bearings frost plugs, shot peened
Canton 5/8 main girdle
Canton windage tray
Canton pickup
Canton 7 qt pan
Procomp 215 heads
2.05/1.60
Doug herbert sprnigs good for 720 lift at installed height
Doug Herbert titaium retainors
Comp cams super locks
Arp 7/16 screw in studs
Doug herbert solid roller lifters
Trick flow hardend pushrods
Comp Cams Pro Magnum roller rockers lifteime warranty on bodys
Stud girdles
Bennet Racing cutom ground cam .698/.688 other spec released to buyer
Procomp Headstuds
Edelbrock Super Victor intake
Proform 950cfm carb
Proform fuel log
Moroso Electric water pump
Ford motorsport double timing chain
Valve cover spacers
Ford motorsport Valve covers
Also will include Proffesional products sfi balancer flywheel
9.5 Converter custom stalled for this motor 4500 stall
