Results 1 to 4 of 4
Thread: Clutch & Pivot Setup?
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Can anyone offer some pointers on the proper way to setup the pivot ball & clutch fork? I have an adjustable cable, firewall adjuster, extended fork, lakewood bellhousing & a spec stg. II clutch/PP.
    I think I have the pivot ball adjusted out too far at the moment. The arm is almost at the back of the window in the lakewood bellhousing. The TO bearing is riding against the fingers of the clutch. I want to see a slight gap between the TO bearing & the fingers of the clutch. Is there an airgap you should look for on disengagement?
    thanks,
    Mark Lowry
    I had to cut my lakewood bellhousing more towards the back of the car where the clutch fork comes thru to get it to work properly.
    978
    Quote Originally Posted by i1arunit View Post
    If you would have shortened the pivot ball would have not had to.
    Caledonia, Ontario
    620
    Chris,
    I should shorten the pivot ball height to bring the TOB just off of the clutch fingers right?
    Mark Lowry
  1. Replies: 8
    Last Post: 09-28-2014, 06:01 PM
  2. I need an adjustable pivot stud asap!!
    By 97LaserRed in forum Ford Parts
    Last Post: 09-16-2011, 07:59 PM
  3. Suggestions on a clutch kit for my setup?
    By Chargin2004GT in forum General Tech
    Last Post: 02-02-2010, 12:15 AM
  4. T-5z, SPEC Stg. II Clutch & PP, Lakewood
    By mlowry1260 in forum Ford Vehicles
    Last Post: 01-11-2008, 12:02 PM
  5. Pivot ball & clutch fork tech question
    By 94Cobra in forum General Tech
    Last Post: 01-04-2008, 08:45 PM
