90 honda crx si-$1,800 w/ Engine below
-prothane bushing kit
-prothane trailing arm bushings
-Front and rear wheel bearings
-Upper and lower ball joints
-New tie rod ends
-Steering rack bushings
-Front and rear swaybar bushings
-Front and rear Brembro rotors
-Front and rear calipers
-EBD brake pads
-Goodridge steel braided brake lines
-E-brake cables
-Toxico shocks and springs - 1.5" drop
-Thermal exhaust
-DC sports header
-AEM CAI
-Front and rear strut bars
-chipped p28 ECU w/ cable to hook to laptop for data logging
-OBD0 TO OBD1 conversion harness
-Walbro 255 fuel pump
-ACT HDSS clutch
-Engine-D16A6 W/ V-TECH HEAD
-D16Z6 head
-ZEX 59300 cam and springs
-port and polished
-Competition valve job
-replaced all seals and gaskets
-5th gen intake manifold w/ integra throttle body
-FIC 650cc injectors
-D16A6 Block -8:1 Compression (built for turbo)
-SRP pistons (.20 Over)
-Eagle rods
-ARP head studs
-3 layer metal head gasket
-Balanced and blueprinted
-Rod and main bearings replaced
-New oil pump and water pump
-New engine pulleys and gears for timing belt
-New timing belt
-Fidenza 5 bolt cam gear
-All new engine seals and gaskets
-100% rebuilt engine
-has around 8k miles on it
-Additional parts-Included with car price
-D16A6 cylinder head
-Comlete A/C system for crx
-Prothane shifter bushings
-Misc. parts that came off car
