can you advance or degree a cam with out taking the rockers and lifters out or can you just put a wrench on the cam bolt and turn it?
Generally you need to loosen the valve train. Is the cam timing out?
Not lined up as in how? With the marks on the front cover? You could turn the key and jump the relay with a screw driver if you dont have a helper. All this while turning the dist. to get the thing to start. It could be out a tooth or two and not allowing enough movement either way.
Ouch how you didnt rebend the valves
89 Mustang (stock) DD
82 Trans Am (not stock)
98 Audi A4 (not so hurting)
i got it lined back up and put it all together and it still wont start, doesnt even try to start. did i mention i HATE this car?:mad1:![]()
