Results 1 to 11 of 11
Thread: Broken oil pump drive
    Belle Vernon
    1,294
    Like the title says, I broke the drive that goes from the oil pump to the distributer again. I broke it last year in the same exact race. I don't think I should be breaking these. The car is only making 350-360 RWHP running 11.40's N/A. Has anyone heard of this problem or know what might be causing these to break?
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    Mt Pleasant
    2,916
    are you useing a hardend shaft or stock?
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    also what kind of pump is it ive heard of high pressure pumps breaking shafts and also how old is the pump
    Belle Vernon
    1,294
    Last year it was the original pump and I figured it locked up from being old, so I put a meiling standard pump in and it broke in a couple months. The shalft is probably stock it came with it from advance auto.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    Huntingdon PA
    1,136
    lol maybe it's just me, but if i broke the shaft last year, i'd be getting a hardened shaft brotha!!
    709RWHP/750RWTQ
    Mike using a stock shaft is just pushing your luck. Just get a good hardened shaft before you waste that motor.
    Summit list of hardened pump shafts for 302.
    http://store.summitracing.com/egnsea...115+4294840126
    I had a pump go in an 88 LX with 250XXX miles. It snaped the shaft. Besides that, it shouldnt be going.
    Belle Vernon
    1,294
    Thanks Ed, I'm definitely getting one of those shafts when I do the motor. By the way that a nice pic of the pumpkin with some air under the tires.
    '89 Mustang GT
    '04.5 Duramax
    www.jonesrv.com
    Is this again (3rd time?) after we talked at the track last?
    Based on the number of broken timing parts I've seen just on this site, I would put hardened "everything I can find" in that part of the engine. I would want to understand the "why". If you put a hardened drive shaft in there, will it just transmit the problem to anther place in the timing drive like what we saw with some of the others with cam and crank keys???
    I'm not much help beyond that, I have a timing belt, but the oil drive on my junk is hairy at best and will not tolerate a high pressure pump.
    I would take the oil pump apart and see that nothing is in it to cause any sort of bind. Little piece of gasket jammed in pump gears can do wonders to a pump shaft I have seen.
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    I've used several brands and I have to say the ARP oil pump shaft is the nicest. It's big enough that it doesn't need the anti-pull out clip. And it's only like $1 or 2 bucks more than the FRPP unit.
    Mark Lowry
  1. N.I.B. M 6605-B302 Oil Pump Shaft
    Last Post: 08-27-2013, 01:29 PM
  2. oil pump question.
    Last Post: 08-13-2011, 10:18 AM
  3. which oil pan,pump for my 408w?
    Last Post: 03-08-2011, 02:50 PM
  4. NEW Ford racing 302 oil pump
    By PSPstang in forum Ford Vehicles
    Last Post: 07-03-2009, 11:07 PM
  5. Oil pump
    By LXguy88 in forum Fox-SN95
    Last Post: 09-30-2007, 04:45 PM
