Results 1 to 7 of 7
Thread: What Mark 7 parts to pull?
    Cheap SOB
    Baltimore, Maryland 21236
    288
    I stumbled across a 1990 Mark 7 LSC in the salvage yard today. What parts should I pull?
    The rear is an okay rear for a 5 lug conversion.
    What the front hubs?
    I heard it has a great ABS setup on it. Can that be used?
    The engine is just another 5.0 HO, right? No need to pull that.
    The lincoln brake parts are a way to rear disc's and 5 lugs, but both the front and rear create problems.
    The rear need the Lincoln axles that are 1.25" longer (per corner) than a normal fox. This will create all kind of wheel fitment issues although SN95 stuff works. Get the axles, ALL the brackets, and then you will still need early cobra / SVO e-brake cable to make that work.
    The front has great 5 lug rotors, 73mm Calipers, BUT the hub is big and sticks out, and creates wheel fitment issues. Basically if you are putting this stuff on a fox, wheel choices get real slim. The rotors and calipers will bolt up to a fox spindle as a bright spot, and the calipers used to be a popular upgrade (bigger piston)
    I think the ABS on those is the early TEV's system, but am not sure any more.
    If I was going to convert to 5 lug, I would do the SN95 stuff myself. That would only add .75" a corner over the fox stuff.
    Bob Myers
    Cheap SOB
    288
    I have a Baer Big Brake setup waiting to be installed. I was just wondering if I should pull these parts for other Mustang people.
    I have no idea what a TEV ABS system is. I have seen two remarks that the Mark 7's ABS was better then the Mustangs. (no early engagement)
    Big Daddy gmkillr's Avatar
    At the racetrack
    4,193
    The electric fan setup is suppose to be one of the best there is.
    Its suppose to be 4500cfm.
    Corvette Z06
    Growing up.............Not everyone does it!
    GREEN=FAST sweeney1030's Avatar
    johnstown
    570
    Id like to get a set of the mesh 16x7 rims .if they are there they look like trans-am GTA wheels , bbs type ; if they are available let me know -- thanks
    Cheap SOB
    288
    Quote Originally Posted by sweeney1030 View Post
    They are all there. I did not check for curb rash. They do have lug locks on them. If the key is there, I will try to pull them for you. If I only get two off the car, do you still want them? No spare, I grabbed it for my future 5 lug conversion. If you want to fight them off the car your self, PM me and I will you directions to the salvage yard. (in Baltimore)
    Cheap SOB
    288
    Quote Originally Posted by gmkillr View Post
    I forgot about that item. Unfortately ths LSC rearended someone. That fan is hidden in the mangled metal.
  1. dyno pull
    By Pure Stock in forum Pictures & Videos
    Last Post: 03-14-2011, 07:25 PM
  2. Pull over thread
    By 95V6 in forum The Bar
    Last Post: 08-05-2010, 01:21 PM
  3. '93 Lincoln Mark VIII complete car for parts
    By biminiLX in forum Ford Vehicles
    Last Post: 07-30-2009, 09:13 AM
  4. Pull out of Iraq? We should pull out of Chicago
    By Twin01cobra in forum The Bar
    Last Post: 10-28-2008, 08:01 PM
  5. U-Pull It Phone #
    By coralcoupe1993 in forum The Bar
    Last Post: 05-11-2007, 11:08 AM
