I am doing teh fox body TB conversion on my car and need the following parts
Fox TB IAC
Fox Throttle cable
Fox Cruise control cable
Fox throttle cable bracket
Fox Fuel injector wiring harness side of the TPS sensor
Fox EGR valve (and a 5\8" cap to block off the EGR port on your header)
Fox EGR spacer (with Fox TB studs) if not using a '93 Cobra intake or EGR delete plate to mount throttle bracket.
Fox Vacuum tree (available at 50resto.com like most of these parts)
Tubing to run from the VC filler neck to the TB PCV tube connection if not using SN95 port
Thanks in advance
