87 LX vert White with White top, Gray leatherette sport seats
Auto trans
Pony Wheels with newer<about 3k miles> Hankook 245/50/16 VR all season performance tires.
126k miles
Now for the full details.
Body is in OK shape. Passenger door has a decent size dent that i worked out but if you take off the pass door panel im sure the rest would bang out. It needs paint...the clearcoat isnt much anymore and has its fair share of dings and little dents with some chipping on the hood and the typical yellowing of the bumpers.The top is in ok shape...the plastic back window shows some scrathes..the top works perfectly though so no problems there. Top is white and is discolored from dirt and sitting outside for a long time before i bought it.
Trans has 3k miles on it, I spent 1500 on it 2 months ago and it has a 1 year warranty. Shifts great and works great.
New front wheel bearings,rotors,performance friction pads,new rear wheel cylinders
It honestly could use shocks and spring isolators...but what older stang couldnt.
Front crank seal does leak some...might get that done soon.
Has MAC cold air intake, Hedman Equal length shorty headers, pypes offroad stainless Xpipe and Spin-Tech Prostreet dumps.
It has an older Alpine head unit that "works" doesnt play burned cd's all that well and the radio isnt wired the best...not my doing...it wont cause a fire or anything just not something i would have done.
Car has power mirrors but manual locks and windows. It could use top weatherstripping just for air noise sake when driving on windy days.
The drivers seat is a little torn up from wear and tear.
It needs motor mounts..i havenew ford ones in a box.
I think it needs a fuel pressure regulator...have a new ford one in the box
New Ford plugs,wires,cap and rotor, although the belts and new hoses are aftermarket.
New ford Heater core just installed...but it needs a blower motor resistor as the fan only works on high.
The vents dont work as we forgot to plug the vaccum line back into one of the blend door acutators...the a/c compressor works but it could use new a/c lines...everything is there.
The sec. air injection has been cut of and the tubes welded shut but the smog pump is still there...never got around to getting a delete kit.
Has new battery also..the biggest i could fit in there...ill have to check what size now cuz i dont remember.
I can provide pics of anything and everything. Might be picking up my roommates 98gt so this one may have to go...let me know what you guys think. I can deliver within 100 miles is someone's looking to do that. So just hit me up guys with what ya might wanna do.
Thanks, Vince
