Results 1 to 20 of 29
Thread: This thread is for those who have ran a new best e.t. this season.
    Like the title states, list some of the incrementals from your timeslip. If you feel inclined, list some of the parts it took you to get the e.t. Perhaps you may want to talk about future mods planned for the upcoming season as well.
    *100% OEM N/A 302" short block
    *Heads, Cam, Intake
    *TKO Trans.
    *Assortment of suspension products courtesy of QA1.
    *28x9x15 M.T. E/T Drag slicks
    *93 octane Sunoco gasoline
    *9:1 compression ratio
    *MSD 6-AL
    *Motorsport Extender (used to get by the 6,250 rpm factory limiter)
    *Spooled 8.8" rear
    *Rear wheel power output measured through a Dynojet in SAE *367*
    *Vehicle weight with driver 2,825 lbs.
    Found an additional 14 peak RWHP from last outing. Some weight was also shed. (around 45 lbs.)
    previous best was: 10.716@123.96
    New best is: 10.604@125.22
    Future mods:
    *looking to lose another 50-65 lbs., mostly off the nose*
    Somerset Co.
    2,907
    I didn't really do anything to the car, I just tried to figure out how the car needed to be launched and shifted. Started out with a 12.6 @110 and with about 5 trips to PRP and after 15 passes I got it down to 12.28 @117.98 (left lane). Every time I went it got faster. I want to run 11's on the stock pulley and tune (full weight) so for spring I'm going to try MT DR's and a better heat exchanger. The MGW shifter will probably get tossed for a Pro 5.0 too.
    Ligonier, PA
    6,365
    Yea.....my beast ran a 14.1 at norwalk......im gonna have to credit that to removing the back seat.....oh and lowering the pressure in the rear to about 22 psi....those major high h.p. mods helped me get that blistering time.
    2018 Jeep Grand Cherokee
    1931 Ford Model A - Project
    1991 BMW 325iX
    1978 Ford F150
    1952 Ford F2 - Project
    Bullitt Rowleyxlt619's Avatar
    Greensburg PA
    299
    03 GT 5spd...
    as the sig says
    Flowtech long tubes
    Flowtech o/r X pipe
    Mac Cat back
    BBK cold air intake
    BBk 75mm throttle boyd
    Trickflow plenum
    FRPP 3.73 ring and pinion
    Roush Racing Short Throw Shifter
    Royal Purple 5w30 oil
    Sonoco 93 octane
    Mickey Thompson E/T streets 26x11.50x17
    06 season went from a 14.4 to a 13.9 with bbk shortys, o/r h pipe, mac cat back, bbk cold air intake, and a throttle body spacer, on street tires
    07 went from a consistent, 13.4 on MT e/t street radials and diablo tuner to from anywhere from 13.3s down to 13.1s wit a best 1.71 60' time with MT e/t streets and the long tube set up... ended up snapping the driver side axle one night up at prp back back in August...
    Plans over the winter...
    Already got a 01 cobra front bumper, cowl hood, smoked headlights. planning on getting bbk underdrive pulleys, msd coil packs, aluminum drive shaft, and 2 deep dish black bullitt wheels...
    2003 Ford Mustang GT
    AMAZON GREEN METALLIC, 4.6L, 5spd
    Best quater mile time-12.96 @ 103.45 (4/6/08)
    Best 60' time- 1.71 (4/6/08)
    1993 Ford Mustang GT
    93 Cobra Teal Met. 5.0, 5spd
    Jun 2007
    N. Huntingdon
    1,596
    Well for me this will be kind of a baseline.
    I had an 89 Corvette with some intake,exhaust mods, and ran a 13.75 @ 99.98 at PRP.
    My first run in the Mustang was a 13.65@105 i believe. 2nd run was 13.13@108. My third and best run that day was a 12.93 @ 109.21 with a 1.86 60' time on 555 street tires. This year the only difference performance wise will be 555 drag radials. Maybe I'll be able to shift faster too; that may of also been the reason I wasn't really satisfied with my ET's.
    goal this season: launch harder w/ the new DR's and sharpen up on shifting
    goal time: 12.30 or lower @ 110-115 MPH
    Chris
    2016 Chevrolet Volt
    2010 Jetta TDi Cup Edition
    1964 Lincoln Continental
    3,316
    No times in a mustang... yet... thats changing this spring
    the neon is a different story. did a turbo change and put DR's on it and went from 13.7-13.8 at keystone to 12.5-12.6 at QCR.
    I Ran The 14.6 With The Svo , Plans Are To Add A Bigger Turbo Tubular Manifold,roller Cam, And Lots More Boost Times Should Drop 3 Sec Or More.
    3,316
    goin with the ranger cam or something from essy?
    North Hills
    1,229
    All i did was dyno. 448 RWHP on a mustang dyno.
    looking for times this upcoming season.
    Current setup is a mostly stock 1968 longblock BBF, with a mostly stock 72’ c6 tranny, 3.50 gears, 26” tire, 3520#.
    Engine/tranny:
    1.) Mill, port, and install larger valves in the stock heads
    2.) Install new flat tappet cam
    3.) Add kickdown linkage
    4.) Install ratchet shifter
    Chassis:
    1.) Weld-in new floor pans
    2.) Weld-in subframe connectors
    3.) Install cal-tracs
    Steering:
    1.) Check ball joints/tie-rod ends
    2.) New 19:1 FR steering box
    Tires:
    1.) Buy way overpriced 18" MT DR's
    After all this there’s no mo money left for a stick like I had hoped…it would cost $2500 plus to put a stick in this car…guess I’ll be rocking the auto again next yr. doh
    Goal for next yr is 11.7x’s on the 18’s….mph expected is 115-117.
    I like running the car at the track just like I run it on the street…..but I just might borrow some real tires for a session to see what it will do.
    I wanna see what you come up with there ;)
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    started the season of in my 91gt with a 11.6@124 on 7lbs and next to no timinig finished with a best of 10.6@132 added more boost and gave it some more timing could stand alittle more timing yet but im going to a bigger blower with hopes of 10.5 or better i would be happy
    Member fin1's Avatar
    Bethel Park
    81
    Started the season @ Thompson running 11.2x with the new trany, wheels & roll bar. Finished the season up with a best of 9.90 @ 140 at PRP. Switched from 110 to C16 in September and increased the timing and boost. Killed a trany, tq converter and turbo in the process and went through a set of M/T's.
    Also managed to lose a bearing on the trailer while coming home from PRP. That required a new axle and brake system after it caught fire a mile from home.
    Overall, it was a good season. ;)
    Brad
    PowerHouse Turbo: www.powerhouse411.com
    9.79 @ 135 1.36 60'
    North Hills
    1,229
    my best time was a 13.1 last time i made it to the track 2 years go. id like to see a low low 11 / high 10. this year.
    Mars, PA
    1,696
    2001 Gt Automatic
    BBK catted x and SLP LM2 catback
    C&L upper plenum with a 75mm BBK tb
    K&N FIPK2
    FRPP 4.10's
    Steeda underdrives
    SGS tune: 242rwhp/279rwtq before pullies. Thinking maybe 250/285 now if i'm lucky.
    Only suspension mods are Lakewood 50/50 shocks and an Eibach Pro-kit.
    Ran a best this year of 13.28@103.71 at PRP on MT ET Street radials at full weight.
    Over the winter i'm planning on a stall conveter and aluminum ds along with control arms and subframe connectors. Maybe some weight reduction thrown in too.
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    ok maybe 2 seconds lol. if i get bigger inj, i know it will pick up a bunch
    Ended last year on 10/15/06 running a best of 12.71 @ 106.79, only changes from 2006 was switching to Royal Purple 5w20, NGK Iridium spark plugs and adding the K&N FPIK cold setup. Ran 12.59-low 12.6s most of the spring/summer after the three things I changed on 3 year old Hoosiers with hammered sidewalls. Sixites varied alot from with good 1.62 to just spinning the tires off.
    Ended this year on a new best(always seems to happen last time I goto track each season)
    MAC Headers & 2.5" exhaust thru cats(Catco's), full suspension(mix of QA1 front, Steeda rear, Strange struts/shocks), weight removed, factory longblock(intake to oilpan, never opened) Spec2 clutch(2nd season of 6k launches), Steeda Triax, TCI Linelock, Detroit Truetrac diff, Moser 31splines, seriously hurt FRPP 4.10 gear that won't die, Hoosier 26x10 slicks(3rd season), bunch of other misc crap. Link in sig
    3135lbs with driver as per IHRA Techs
    10/28/07 @ 1:54pm
    1.68 sixty(spun)
    5.09 330'
    7.96 1/8
    85.39 1/8 mph
    10.43 1000'
    12.51 1/4
    108.30 1/4 mph
    Car went 12.57 before best pass then back to back 12.53's after the 12.51 Spun on every pass and ran 108-109mph in right lane and 112mph left lane
    Doubt I will do much more to car. Tempted to put back close to stock since most my time will be focused on getting the '84 vert ready for next season. Finally have 351w block for it. Nice lil stroker planned just need to decide on heads and go from there.
    Boost away
    10/28/07 @ 1:54pm
    1.68 sixty(spun)
    5.09 330'
    7.96 1/8
    85.39 1/8 mph
    10.43 1000'
    12.51 1/4
    108.30 1/4 mph
    Hey man, it's refreshing to see someone wring out a combo as you did. You have a solid 2 tenths at a quicker/faster track. It's hard to give up on a hard charging combo, especially with minimal mods. Believe me, it damn near killed me to pull the E7TE's off my junk.
    Nice e.t.'s guys. Keep 'em rollin.
  1. I need this vin# ran asap.
    By 2001GTTT in forum The Bar
    Last Post: 02-23-2009, 11:38 PM
  2. ran into a slight problem... help please
    By Johnny B in forum General Tech
    Last Post: 01-31-2009, 05:23 PM
  3. just a cool old house i ran into today
    Last Post: 12-08-2008, 01:38 AM
  4. Ran the Turbo Focus: 14.74@95.97 (vid)
    By sutyak in forum Drag Racing
    Last Post: 09-03-2008, 06:03 PM
  5. i need a carfax ran.
    By J-rod in forum The Bar
    Last Post: 11-10-2007, 10:08 PM
