Results 1 to 17 of 17
Thread: WTB SN95 Smog Delete Pulley
    Senior Member 95DropTop's Avatar
    Gibsonia, PA
    323
    Hello. I am looking for a smog delete pulley that will fit a 1995 Mustang GT.
    Thanks.
    3,499
    I know a belt re-routing on the older 5-Liters negates the need for a idler. Not sure about the SN-95's belt configuration.
    Got Boost?
    West Mifflin
    1,442
    Im pretty sure i have one. Gotta check the pile. If i do 30 bucks its yours.
    2013 Race Red F-150 Screw FX4 Ecoboost
    1994 Rio Red GT
    10.60 @122.88
    Sold
    you could run without it, but with the pulley you can use the same belt
    Robinson
    3,842
    I think I have one. If not, Wick has it. E-mail him.
    87 GT
    93 Notch
    60 Country Sedan
    Fairlanes/Galaxies 59-68
    67 Contiental 4 door
    06 Powerstroke
    88 5.0 lx conv eddmann55's Avatar
    irwin
    538
    this might be a better idea anyway in case you ever decide to sell the car
    irwin
    538
    I ditched mine and run a shorter belt. the belt goes from the crank, over the tensioner, and to the alternator, the rest is the same as the stock configuration. I've run mine like this for years.
    irwin
    538
    not sure if the chart helps with yours
    Belt Length
    How Long Would A Belt Be For A 1995 With No Ac Or Smog Would It Be The Same As The Fox
    Quote Originally Posted by tylerstepp View Post
    yup
    Thanks
    Thanks Thats Good Info
    Gibsonia, PA
    323
    Quote Originally Posted by eddmann55 View Post
    Yes, understood. The problem is that I am about to install a set of GT40P heads and they don't have the proper openings for the thermactor so the smog pump is not really useful. I guess that I have to either ditch the heads and opt for different ones, get them machined for the thermactors (too expensive, likely) or rip out the smog pump. Anyone have any ideas? Do aftermarket aluminum heads have provisions for the smog pump or no?
    irwin
    538
    if you decide to sell the heads let me know
    Big Daddy gmkillr's Avatar
    At the racetrack
    4,193
    Tyler, its a 895K6, i'll be dropping it off at Wolfpack for you tommorow.
    Corvette Z06
    Gibsonia, PA
    323
    Thanks, yes it helps. The more I read here and elsewhere, I think that I am going to just keep the smog stuff in place and drill or weld studs and attach the piping to the new heads. The smog system won't be exactly right without the thermactors but should work with the engine hot and keep me out of emissions grief. I think that I will just tear the engine apart and see what I need to do and go from there. Thanks guys for the thoughtful advice and sorry to those of you rooting through parts to find me a delete pulley.
    Quote Originally Posted by 95DropTop View Post
    Thanks.
    Hey, I got your message. I actually tried an experiment with the one I had. When it did not work, I threw it in the scrap pile.
  1. Belt Length For A/C And Smog Delete
    By Dickbag 5.h0 in forum Fox-SN95
    Last Post: 06-14-2012, 05:17 PM
  2. smog pump delete questions
    By geps91stang in forum General Tech
    Last Post: 12-02-2010, 04:24 PM
  3. Smog pump delete?
    By PITT40 in forum Fox-SN95
    Last Post: 06-18-2010, 10:32 AM
  4. FS: Smog pump delete kit
    By blkp42e in forum Ford Vehicles
    Last Post: 03-24-2009, 02:09 PM
  5. smog delete
    By scott5 in forum Ford Vehicles
    Last Post: 03-28-2007, 10:53 PM
