I'm no expert on Nitrous set-ups, but..........
When I was planning out my stuff, I thought I might want to spray on it at some point. I also new I need an igntion box (big boost ;) ). So when I went shopping, I came across this:
http://www.jegs.com/webapp/wcs/store...10002_48546_-1
I only use mine as an ignition, but it has two features that would be really cool for a nitrous set-up. There is a built in window switch that is pretty much needed, plus a single stage timing retard. Basically, that will pull out "X" degrees of timing when active. Basically, you can fire your notrous system off the window switch, and bring the power in to retard the timing when on the spray, but still run your "agressive" timing off the spray.
MSD has similar with their digital 6 box. Not what you asked specifically, but something to consider if you want a "safe" system.
