Results 1 to 17 of 17
Thread: will these work in my car
    88 5.0 lx conv eddmann55's Avatar
    irwin
    538
    I have a set of 24 lb injectors i aqqired a while back, i'm in the middle of putting new heads and intake ect.... will these fit my 88 5.0 with the stock fuel rail? as you all probably know the stock ones are fatter
    North Hills
    1,229
    dont think so.
    irwin
    538
    ok wasn't sure the plug is the same other mating parts don't look same, im not worried where it goes into manifold, but where they go into the fuel rail looks different
    They will work, but you will need harness adaptors to use them with your fuel injector harness on your car.
    irwin
    538
    sounds like more than a pain than it's probably worth?
    irwin
    538
    the wire harness? the plugs are the same
    Quote Originally Posted by eddmann55 View Post
    Never mind then. Those looked like then new "pencil style" injectors in your pic. Those had different wiring connectors than the harness in a fox.
    irwin
    538
    those aern't the exact injectors just a random pic i found
    So why use the pic. If they're 24# they should look almost exact as the stock ones, just a different color.
    irwin
    538
    they are thin like those ones,
    irwin
    538
    i'll just buy the right ones
    Farmington WV
    4,672
    i was thinking the same thing as ed.
    i just aquired a set of 30# inj from a Tbird SC...those will work in the 5.0 motor. i used to run 5.0 inj in a couple of my V6 stangs
    irwin
    538
    i fitted them they fit ok the wires fuel rail and manifold
    are they just a different style that they are skinnier? any advantages or disadvantages anybody know?
    Member RUSH2112's Avatar
    Hopewell, PA
    754
    I have a set of #30 ford injectors if you need them
    pa
    860
    I GOT A MASS AIR FOR THOSE 24# INJECTORS IF YOU WANT IT. Granatelli 74MM BULLET.
    i will have some 24lb injectors and a 76mm mass air in january for sale.
    irwin
    538
    I did a little research they are just a newer style and supposedly more efficient, they are also for the bigger sizes they make them up to 160 lbs and they will work in my car, also they are 27 lb not 24
  1. Replies: 13
    Last Post: 07-19-2014, 11:47 AM
  2. Car for work
    By THE BIG KOALA in forum The Bar
    Last Post: 09-07-2013, 09:22 PM
  3. FS: Winter/work car
    Last Post: 11-23-2009, 01:55 AM
  4. Rental car policy at work
    By venom in forum The Bar
    Last Post: 04-14-2009, 04:18 PM
  5. FS: Work ride/winter car
    Last Post: 11-15-2008, 12:53 AM
