Results 1 to 15 of 15
Thread: Vibration Question
    Selinsgrove, PA
    526
    Vibration Question
    Ok, well i have been noticing lately that when my car hits from like 80-85+ it starts to vibrate/shake, anybody know what this could be, i bought new tires, had them balanced, checked the driveshaft and it seems to be fine...
    Any other suggestions on what to check??
    Fox/n.
    Front end alignment.
    Selinsgrove, PA
    526
    positive thats what it is? because if thats it, ill be so happy... lol
    Fox/n.
    out in the woods
    4,948
    is it in the steering wheel? the seat? the shifter?
    work
    4,057
    I would have to agree with the alignment. Not that I know alot of the technical stuff, but my celica used to do the same thing. I had the alignment done and tires changed and balanced and it stopped.
    X2 - good question to diagnose with. One other, soes it do it under power only or both drive and coast?
    I dont think you can "look" at the driveshaft and tell if its okay. One other thing I've really seen, all the stock driveline dampers on these cars are getting old, the rubber dries out, etc. Mine actually smoothed out after I took the "dogbone" off the housing since it was so hard it wasnt doing its thing.
    out in the woods
    4,948
    this was gonna be one of my advise parts to check...
    Selinsgrove, PA
    526
    its if im on the throttle or just coasting at like 80-85+, and it feels to me like the front is whats vibrating.. not the shifter, the seat a little, an i dont think the steering wheel vibrates at all...
    Fox/n.
    Does it go away if you go faster or get worse? You dink a curb lately?
    A quick test would be to swap the rear tires to the front. While you are doing that, take a good look at everything for loose / broken / worn stuff. If swapping the tires doesent change it, you need to go deeper.
    Somerset Co.
    2,907
    Quote Originally Posted by Black87GT View Post
    Did you re torque the lugs after you had the wheels put back on?
    Selinsgrove, PA
    526
    Yes, and no i havent hit any curbs lately, i think that its just that my car needs aligned... *Hopes*
    and by going faster it stays the same, if not getting worse, i mean right when it starts to vibrate i back off, because im worried about breaking something, and breakin something doing 80+ wont be fun..
    Fox/n.
    North Hills of Pittsburgh
    430
    I also had vibration issues last year(see thread below). When I spoke to Hoss at Hoss' Gear Shop about my issue, he said vibrations are almost always related to the driveshaft if the suspension and tire balance issues are ruled out.
    http://www.steelcitystangs.com/forum...bration&page=2
    2016 GT Premium
    did the front ires you took off look real choppy? and did you ever check the ball joints and tie rods??
    Selinsgrove, PA
    526
    tires i took off were like brand new when i bought the car, so there was hardly any wear, and no i havent checked ball joints or anything ..
    Fox/n.
    out in the woods
    4,948
    jack up the car and put your hands on 9 & 3 o'clock on the tire, wiggle side to side lightly to see if there's any play this will check the tierod ends.. then either put hands on 12 & 6 do the same to check for play on the wheel bearings. or you can put a fourway under the tire and pull up on it lightly to also check wheelbearings.
  1. Vibration Question Again?
    Last Post: 06-13-2008, 09:06 PM
  2. Vibration Question
    Last Post: 04-03-2008, 10:50 PM
  3. Vibration
    By wick in forum General Tech
    Last Post: 05-28-2007, 02:15 PM
  4. Bad Vibration
    Last Post: 04-02-2007, 02:50 PM
  5. Nasty Vibration
    Last Post: 03-21-2007, 05:54 PM
