Results 1 to 6 of 6
Thread: Fiberglass Hoods and RFI
    member 65 Fastback's Avatar
    Nov 2007
    South Hills
    303
    I was watching the Barrett-Jackson auctions the other day, and they mentioned that a 1970 Cuda had a factory fiberglass hood. The antenna had to be moved to the rear since the car no longer had a metal hood to block RFI's.
    Is this true on modern day cars as well that have aftermarket fiberglass hoods? I have never heard of this before.
    Most newer mustangs up to '04 use fiberglass hoods. They do also have a grounding strip from hood to body.
    Nov 2007
    South Hills
    303
    Does this mean that if I put a 'glass hood on my '87, I should ground the hood? Wouldn't the metal hinges ground it to the body?
    I am an RF tech by trade...
    In the 70's when the Cuda came out most cars came with AM radios. AM is very prone to ignition noise. When you cover the engine/ignition with a METAL hood and ground it it shields the noise from getting into the radio. We all use FM ( not prone to noise for several reasons)... one being MUCH higher in frequency.
    Any other questions?
    Mike
    if you want to try an experiment...take a cell phone stick it into a grounded metal mail box and close the lid...it probably won't work unless your very close to a cell site
    best of 9.66 at 141 MPH
    http://www.mikeymustang.com
    Nov 2007
    South Hills
    303
    Quote Originally Posted by mikeymustang View Post
    Mike
    Thanks Mike, I never thought about the AM versus FM feature. I was just curious about this whole idea. John
    Farmington WV
    4,672
    94 was when they started stock glass hoods
  1. Painting any hoods?
    By Darren in forum General Tech
    Last Post: 01-11-2011, 08:19 PM
  2. good fiberglass hoods for a foxbody
    By Gray 5.0 in forum Fox-SN95
    Last Post: 05-19-2010, 05:54 PM
  3. Whats the deal with the unpainted hoods?
    By delldoe in forum The Bar
    Last Post: 08-25-2007, 02:59 PM
  4. Old Cobra hoods
    By One Sweet Day in forum The Bar
    Last Post: 08-23-2007, 08:52 PM
  5. where in the world do you buy kaenen hoods?
    By PunisherStang in forum SN95-New Edge
    Last Post: 08-07-2007, 02:31 PM
