ok having a problem with the f150....its a 94 with the 4.9L inline 6. 5 speed tranny (actually 4 speed and an 'overdrive gear') and 2WD.
i was moving it into the drive way one day and all of the sudden when i pushed the clutch in to put it into first the clutch stuck to the floor and only comes up about 4 inches...i put my toe under it and pushed it back up and now it is loose all the way down till it gets about 4 inches from the floor. it is still drivable but im afraid the clutch is not completely dis-engaging when i press the clutch in.
it is a hydraulic clutch and i checked the resevoir and has enough fluid. the clutch is fairly new and i know the clutch isn't bad as it just happened out of nowhere while moving the car off the road and into my driveway.
did something break or what?
