Results 1 to 7 of 7
Thread: T-5z, SPEC Stg. II Clutch & PP, Lakewood
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Spec stage II clutch & PP, 150 miles, no track time $150
    Lakewood bellhousing, t-5 w/sfi sticker $190
    T-5z, pristine condition, $700, going to Astro A-5 for the 363.
    Mark Lowry
    Farmington WV
    4,672
    pm me an email or phone number. got someone interested in the tranny. she is having her stang trailored home this weekend and pulling the tranny. she thinks its shot.
    also all 87-95 T5 wil work in a 95 right? im 99% sure.
    The 94-95's has a different bellhousing that is about 3/4" longer. This is because the 94-95 tranny's had a slightly longer input shaft. You may be able to use the older T-5 but you may have to cut the floorboard some to get the shifter up thru.
    Caledonia, Ontario
    620
    Jared,
    it can work. There is some difference in the bellhousing & input shaft length from what I read.
    http://www.corral.net/Forums/showthr...ight=94-95+T-5
    From the corral:
    "A Fox T5 will work with a driveshaft spacer AND a Fox bellhousing. If using the 94-95 V8 T5 bell housing with the input shaft of a Fox T5, the input shaft will not mate up to the flywheel/pilot bearing. Personally I would find a 94-95 specific bell and transmission. It is just less hassle all around without having to find a driveshaft spacer and the interference the shifter would have with the opening in the floor pan."
    Mark Lowry
    Farmington WV
    4,672
    thanks guys. i dont figure she will want to go through the hassel.
    ill let her know though and she can decide. she may want a 94-95 spec
    Jared, all she would need is a DS spacer. Many places sell them and they are not that much. There should be enough room in the trans crossmember where the bolts go in to allow the transmission to slide forward the approx 3/4" it needs to if used in a '94-95. Its basically just like putting a TKO in a 94-95, you have to do the same thing. The only other thing she may need is a longer clutch fork. You can get the fork and spacer from promotion performance powertrain.
    Farmington WV
    4,672
    i will pass this on.
  1. Spec 2 Clutch
    By 2000GT in forum Ford Vehicles
    Last Post: 09-01-2014, 09:04 PM
  2. 96-04 Lakewood Blowproof Bellhousing SFI SPEC 6.1
    By billyNOTnice in forum Ford Vehicles
    Last Post: 06-25-2013, 08:55 AM
  3. FS: Spec Stage 2 clutch. Almost new!
    Last Post: 07-24-2011, 07:23 PM
  4. Spec Clutch
    Last Post: 05-13-2011, 06:58 AM
  5. spec clutch for 2.3 4 cylinder
    By fast4ord in forum Ford Vehicles
    Last Post: 02-22-2008, 10:02 AM
