Results 1 to 7 of 7
Thread: Who says the E303 cam is junk?
    Car: '84 Mustang
    Engine: OEM '91 HO short block
    Cylinder Heads: '71 351W 1.90" intake, 1.60" exhaust, mild port
    Camshaft: FRPP E-303
    Rockers: 1.6 ratio Harland Sharp
    Compression: 9.5:1
    Carb: Carb Shop 750cfm Holley
    Intake: Weiand Stealth, unported
    Ignition: MSD 6A, Soft Touch rev-limiter
    Distributor: Accel billet
    Timing: 35 degrees total
    Fuel Pump: Carter self-regulating, electric
    Exhaust: Equal length shorties, 2.5 in. H-pipe, Flowmaster 3-chamber
    Trans.: Transmission Specialties C4 transbrake
    Convertor: Transmission Specialties 8 in. 4,700rpm stall
    Shifter: B&M Pro Ratchet
    Flexplate: ATI
    Driveshaft: OEM
    Rear: Dana 44 w/Detroit Locker
    Gears: 4.27:1 Precision gear
    Axles: 30-spline Dana
    Suspension: Koni adjustable struts and 4-cylinder coils, Front; Koni adjutable shocks, Moroso Trick springs, Steeda aluminum lower control arms, FRPP upper arms, airbag, rear;
    Sway bars: Front removed
    Chassis: Competition Engineering subframes
    Lubricants: Amsoil 10W-30, engine; Castrol Type F, trans; Amsoil 75W90 gear lube, rear
    Tires: P165 radials, front; M/T 26x10, rear
    Wheels: Weld Draglites, 15x3.5, front; 15x10, rear
    Weight: 3,030 lbs. incl. driver
    Launch RPM: 4,700
    Shift RPM: 5,800
    Best 60': 1.56
    Best ET/MPH 11.94@109.45
    I do! I say all of the alphabet cams are junk. Imagine what that car could do w/ a good cam in it.
    11.9's with ported 351 heads and a 5,800 shift point with an emissions legal cam does not sound like junk to me. It's all in the combo though.
    i love the fms cams. i have always had good luck with em. Had a car that went 11.50s with an f cam and 150hp shot..
    I Would Say The 3030 Lbs With Driver Doesn't Hurt Times At All
    3,356
    I ran easy 11.40's years ago with 10# of Vortech boost and a E303. Full weight car, no driver mod, and that's all.
    Mark
    LeMans Blue Z06
    yeah.......;)
  1. F/S: Brand new E303 Cam/Lifters and BBK Shortys for 5.0
    By Black89GT in forum Ford Vehicles
    Last Post: 06-23-2013, 09:25 PM
  2. E303 Cam Stock Intake
    Last Post: 07-18-2009, 08:20 AM
  3. Cam motion billet solid roller cam for sbf
    By SK@StreetLethal in forum Ford Vehicles
    Last Post: 05-18-2009, 12:57 AM
  4. wanted e303 or trick flow stage 1 cam
    By silverworm in forum Ford Parts
    Last Post: 08-03-2007, 02:52 PM
  5. FS: Motorsport E303 Cam
    Last Post: 06-06-2007, 10:01 AM
