Results 1 to 20 of 34
Thread: N/a 347, 466 Rwhp
    N/a 347, 466 Rwhp
    Copied and pasted from the corral.
    Took the car down to the dyno yesterday after having it torn down replacing valvetrain parts in an attempt to fix a high RPM power drop I was encountering last time I was on the rollers. The last time on the dyno the car made 453 RWHP @ 5900 rpms and shortly after that power dropped due to instability in the valvetrain. I know another member of this board made 454 @ around 6800 rpms with race gas in the tank and a bunch of timing. So I figured 453 @ only 5900 with 91 octane and only 30 degrees total timing was pretty good But of course the valvtrain issue needed to be sorted out to see what this setup could really do.
    At the end of the session the car was puting down 466 RWHP and 427 RWTQ!!! All at a nice comfortable 6200 rpms Again, on pump gas, 91 octane and only 31 degees total timing. I'm very pleased with this setup now.
    Combo: http://www.fordmuscle.com/archives/2005/02/YellowFever/
    Dyno graph, SAE power:
    I KNOW OF THAT CAR I HAVE A VID OF RUNNING 10'S , ITS THE COLOR THAT MAKES IT SOO FAST
    Post the vid Troy.
    its at home it helps get me thru the winter
    An inspirational vid, I can relate, I have a few that I re-visit every so often as well.
    that is awesome!
    i wonder what kind of wheels those are..
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    Mark Lowry
    that is awesome!
    i think those are called budniks..
    Caledonia, Ontario
    620
    It's mentioned towards the end of the article for the IM generation...
    http://www.budnik.com/roadwheelitem.asp?scid=91&pid=792&pg=1
    Good lookin wheels.
    Mark Lowry
    Top secret cam specs. Geez, I thought I was the only d$ckhead in existance
    That car has been around for a while now and was the first 10 second NA 347 94-95 car that I ever heard of. From what I've heard, the guy can drive the hell out of that car!
    Looks like he got together on some aspects of the suspension with Kevin Slaby from Baseline Suspension. From what I gather it has gone in the .70's with a 1.46 60' on a drag radial.
    Definitely a stout power producer @ around 1.58 FWHP per c.i.d. You gotta love it when time is spent to dial in the peripherals and the power is unleashed. It is common to see the avg. pump gas 347 struggle to eclipse 400 to the tire.
    Caledonia, Ontario
    620
    Joe,
    this guy at HiTech likes larger intake duration than exhaust. He seems to be successful with it, I'm not sure how he plays with the opening & closing events on the cam. Take a look at some of his cams:
    https://www.hitechmotorsport.com/sto...6c54275039c077
    This looks the top secert cam:
    Specs: 248/244 duration, 108 lobe sep, .584/.576 lift This is the big dog. If you are looking for a cam to go really fast, this is it. In a 347, this one made 430+ RWHP & ran 10.90's at 125 MPH.
    http://www.corral.net/Forums/showthread.php?t=820761
    Mark Lowry
    Xfi248hr-14
    Mark,
    I'd like to try this Comp XFI Hydraulic Roller cam in a 347".
    HYDRAULIC ROLLER-347” or larger. Serious Hyd. Hyd. 3200 to 6500 35-776-8
    hp & tq. in the mid & upper rpm. Best w/ aftermarket
    heads, intake, T-body & injectors. 3500+
    stall or 5 speed. Computer mods a must.
    XFI248HR-14 304 314 248/258@.050" .608/.608 114°
    Did you ever hear about any results e.t./RWHP??
    those comp cams aren't any good i heard they come off shelves i want mine right off the cnc
    Caledonia, Ontario
    620
    Mark,
    Ah Hah,
    Joe finally fesses up on his motor being a 347!
    Mark Lowry
    Ah Hah,
    HAHAHAHA Busted!!!
    Ah Hah,
    It's one of those Hi-Tech 347's. Ya know, the ones with a 3.0" stroke and a 4.0" bore.
    Yes, this car has been around for awhile. He ran 10's on a 18" drag radial.
    Baseline Suspension......
    Clean mineralrob's Avatar
    Pittsburgh
    1,994
    I remember seeing that car awhile back in a magazine article.Nice car though.
    02 MG GT
    98 SVT Contour SF/MNB #2059
    93 Civic Hatch
  1. 500 RWHP made easy
    By scott5 in forum SN95-New Edge
    Last Post: 01-12-2009, 12:41 AM
  2. What 360 RWHP can do for you
    Last Post: 12-17-2007, 11:35 PM
  3. 851 rwhp TT cobra
    By Twin01cobra in forum Pictures & Videos
    Last Post: 07-04-2007, 04:50 PM
  4. Stock RWHP for a 87-93 fox?
    By speedracer in forum Fox-SN95
    Last Post: 04-23-2007, 12:23 AM
  5. Not bad for 360 RWHP
    Last Post: 03-21-2007, 01:41 AM
