Results 1 to 8 of 8
Thread: should i do a main support??
    North Hills
    1,229
    had issues with my last head bolt, so i am pulling the motor out to get it off. and going to install cam that way too, will make it easier. while i have the motor out, should i do a main support and windage tray while i am at it?
    will the main support be a big help in keeping my block together nearing the 500whp mark?
    Windage trays are nice. The main support is not designed to keep the block together. They are designed to help prevent main cap walk. The block can still split from the lifter valley to the timing cover area even with the main support installed. At best, it's a band-aid.
    North Hills
    1,229
    so don't waste my money?
    IMO, quality machine work, attention to detail in assembly, and having the tune spot on helps extend the life to a certain degree.
    There are some examples of stock blocks that last for numerous seasons and they throw everything at them except the kitchen sink. Then there are examples that give way @ 450ish to the tires.
    It's a gamble. My example utilizes a untouched 1993 stock short block that sees 7,000 rpm on the big end. No girdle here. Not getting pounded on every weekend though.
    If I were to do a 332-347, say from D.S.S. I would include a girdle on a piece like that.
    the thing to krrp in mind with a main girdle is you must get the block reline honed with the girdle torqued on the block..
    North Hills of Pittsburgh
    430
    Tim is dead on. I just had my 347 apart after only 5,000 miles and all of the bearings were down to copper because we put a girdle on without a line hone. I was on the fence about whether or not to pull my engine, but I definetley am glad I did.
    2016 GT Premium
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    i agree it doesnt make the block any stronger but i do believe that when they do decide to come apart they are a parts saver. i know a guy on this message board who has gernaded 2 stock blocks save the entire rotating assembly both times and that is a credit to having a gurdle on both engines as for another friend of mine broke his with out a gurdle and we will just say this there wasnt much left that wasnt broke he did manage to save the heads but did bend a few valves so no i dont think it makes them stronger but i do think it saves alot of parts when it happens i would rather spend 150-200 on a gurdle vs 1300-1600 on a good rotating assembly
    2,483
    i agree it doesnt make the block any stronger but i do believe that when they do decide to come apart they are a parts saver. so no i dont think it makes them stronger but i do think it saves alot of parts when it happens i would rather spend 150-200 on a gurdle vs 1300-1600 on a good rotating assembly
    Bingo!
  1. How much horsepower would require a main support?
    By Donstang86 in forum Fox-SN95
    Last Post: 03-07-2014, 04:36 PM
  2. 1000lb engine support bar.
    By NateSVT in forum Ford Vehicles
    Last Post: 08-26-2012, 11:42 PM
  3. Support these Navy Seals.
    By shawnsvtcobra in forum The Bar
    Last Post: 12-28-2009, 12:21 PM
  4. Support Our Troops
    By no1fordgirl in forum The Bar
    Last Post: 12-17-2009, 09:12 PM
  5. Early Fox Foglight Support
    By blizzard in forum Ford Vehicles
    Last Post: 12-20-2008, 01:13 AM
