Results 1 to 11 of 11
Thread: Slight Grinding noise
Hybrid View
    Spencerport, NY
    3,762
    The HD truck is making a noise, which sounds like its coming from the left front that I thought i knew for sure what it was.... its a slight grinding upon every rotation of the wheel when the wheel gets to that point... I thought at first it might be a rotor or the bearings... Well, i thought i could rule out rotor, b/c i can't feel anything at all in the brake pedal... So today, i was going to tear it off and replace bearings, but when i got the truck up in the air and spun the wheel, there's no noise.... Both front wheels spin freely with only the normal little bit of noise from the brake pads contacting the rotor....
    Any thoughts on what else i could look for?
    I figured if it was the bearings, it would make that noise free-spinnign in the air as well?
    2015 Corvette Z06
    - Shark Grey / Kalahari
    Fuwkawee
    5,151
    Maybe it is a small pebble that got stuck between the brake pad and the rotor. I had that happen twice.
    17 Ram 1500 Big Horn Hemi
    16 Comp O GT Performance Pack
    Spencerport, NY
    3,762
    ok, but wouldnt this make noise even when the truck is up in the air??
    That's what i'm most confused by... i haven't take the truck back out since i put it in the air, but it didnt make any noise when i rotated it by hand
    2015 Corvette Z06
    Fuwkawee
    5,151
    Yea I would think it would. I don't know what it would be then.
    KB 2.6 custom fabbed
    Southern California
    311
    You can't judge a wheel bearing problem when the truck is in the air. It needs to be fully loaded on the ground. It sounds like a brake problem however. Wheel bearing will make noise/vibration either all the time, or at a certain RPM. Not at one spot in wheel rotation.
    Member badstanglx's Avatar
    altoona
    676
    needs a wheel bearing
  1. Replies: 3
    Last Post: 06-05-2012, 09:51 PM
  2. pa c4 grinding!?!
    By mplacek in forum General Tech
    Last Post: 03-18-2010, 09:16 PM
  3. ran into a slight problem... help please
    By Johnny B in forum General Tech
    Last Post: 01-31-2009, 04:23 PM
  4. anyplace fix slight curbage?
    By PunisherStang in forum The Bar
    Last Post: 02-28-2008, 07:42 PM
  5. Grinding noise?
    By turbostang3.8L in forum General Tech
    Last Post: 07-21-2007, 03:12 AM
