Results 1 to 4 of 4
Thread: Kickdown Questions????
    Marine Eng. Officer ArmyWarrant's Avatar
    Fort Eustis, VA
    525
    So I get the kickdown hooked up on the AOD I put in my 86 lx v6 and it shifts ok but when you are driving and try to get into it and get the trans to kickdown nothing happens. I looked under the hood today and there is the adjustment screw on the throttle brackets on the throttle body and when I push it all the way to WOT it doesn't contact with the kickdown bracket. I even adjusted the screw as far as I could and it still doesn't touch. Anyone got any pics of the set up on their car so I can see if maybe there is something missing?
    90 GT stock needing some minor work, traded my 87 Vert to my bro for it.
    2004 RAM 1500 Quad Cab Hemi DD Gonna be up for sale soon
    86 Notch New Project
    Fort Eustis, VA
    525
    I got the lokar kickdown cable and am going to install it anyone ever done one before and have Any advice to make it easier?
    i am pretty sure that is supposed to be pulled all the way out when your t-body is at WOT...
    Fort Eustis, VA
    525
    Well, the lokar cable won't work with any of the throttle bodies on the ford 3.8 v6. The stock kickdown that I have seen operates on moving the same way as the throttle linkage which is towards the fire wall and lokar cable requires being pulled toward the radiator. Unless I can come up with a way that the cable can be routed to come in from the front it won't work. I have a stock set up from a 87 tbird that is on there right now and it is working Just need to see if I can get it adjusted because it shifts harder than it should.
  1. 83 GT Questions
    By Darren in forum Fox-SN95
    Last Post: 05-08-2014, 02:36 PM
  2. 5.0 questions
    Last Post: 06-13-2012, 07:51 PM
  3. Questions about...
    By AdamantiumSilvr in forum General Tech
    Last Post: 10-13-2011, 02:31 AM
  4. questions
    By bill412 in forum SN95-New Edge
    Last Post: 01-05-2009, 10:34 PM
  5. C4 questions?
    Last Post: 12-19-2008, 10:34 PM
