Results 1 to 8 of 8
Thread: fuel rail question - do i cut or what?
    3,316
    On my 3.8 v6 it seems like on the feed side and return side of the fuel rails there is some weird compression fitting of some kind. Does anyone know the magic to get the piece of rubber tubing off thats still attached to each end? I messed with it for a while and I (still) havent got a service manual for it, and even the fitting guru had a tough time sorting it out.
    Any help appreciated.
    ps - anyone got a good how-to for clutch reassembly? :)
    Farmington WV
    4,672
    you know what....dont those take the special fuel rail tool? i had to buy a set for like $15.
    if you dont have an asnwer by tomorrow i will go to my building and get the repair book to scan for ya
    3,316
    I appreciate it.
    im doing some google searching tonight. I'll see what I come up with.
    Yeah those are the ford quick disconnects. You can pick up the tools at most parts stores. The tools work on both fuel and a/c lines.
    Farmington WV
    4,672
    Quote Originally Posted by SK@StreetLethal View Post
    thought so. i got mine at autozone for around $15. they were a kit of 5-6.
    That's to get the whole fitting off. As far as getting the plastic line off well that line is shrunk on to the fitting. You can cut it off. What I usually do is carefully split the line and peel it off. The fittings themselves are what you need the tools for.
    3,316
    ah ok.. .thanks!
    Member DING's Avatar
    New Bern, NC
    324
    If you can get the whole line off. You could boil the fitting end and pull off the plastic line when it gets plyable enough. I did that to some fuel line fittings and it worked pretty good. Don't let it get to hot though.
    Hank
  1. Fuel rail issue?
    By RogerStout in forum General Tech
    Last Post: 07-18-2011, 10:01 AM
  2. Fuel rail welding needed
    By CollinsPC in forum General Tech
    Last Post: 04-14-2011, 10:31 PM
  3. Fs:Brand New Fuel Rail's
    By 1foxbody in forum Ford Vehicles
    Last Post: 12-20-2008, 12:50 PM
  4. Fuel rail woes.
    Last Post: 08-02-2008, 01:43 AM
  5. WTB: Fuel rail set
    By blkp42e in forum Ford Parts
    Last Post: 03-12-2007, 11:42 AM
