Results 1 to 9 of 9
Thread: TR3650 nochy shifting??
    Clean mineralrob's Avatar
    Pittsburgh
    1,994
    Just curious what tranny fluid everyone runs and what can make the TR3650 a tad smoother. Mine isnt bad but i've heard stories of people switching to diffrent fluids which make it alittle smoother. Its mainly notchy beetween 1-2 but all of the other gears are smooth as butter. My car has 20k and still has the factory fluid in it(if fluid will even make a diffrence). I've gotten a million diffrent answers that go both ways as far as changing to synthetics etc. Or will these trannys always be notchy and dont worry about it,lol. Any input??
    Thanks
    02 MG GT
    98 SVT Contour SF/MNB #2059
    93 Civic Hatch
    Mt Pleasant, PA
    4,905
    Im not too sure on your trans but my 6 speed really smoothed out when I switched to GM sincromesh.
    Farmington WV
    4,672
    i have heard of many many people using that in everything from T5's all the way up.
    Amsoil makes a counterpart to the Synchromesh. I think its called MTF. Good stuff. I use it in my Tremec 3550.
    Somerset Co.
    2,907
    I was just looking in Jegs and Royal purple has a "syncromax manual tranns fluid" I'm going to assume its of the same nature.
    I use the Royal Purple. Course when mine starts acting up I know it's time to adjust the clutch cable.
    Senior Member Jivepepper's Avatar
    Morgantown WV.
    563
    Mine has a little problem between 1st and second when it's cold. But I bought my tr3650 used for 350, 4 years ago. I run Mobil 1 AFT, with a little over 1/2 quart less than it called for originally. When they do the fix on the tr3650 at ford the recommend to running a little less than ii originally called for. I think there was more of a problem with the 01-02.
    665/540 New times coming
    Old times with 516/453 11.10 @129 Best trap 130.69 -750' DA lol
    DYNO VID ---> http://www.youtube.com/watch?v=K9uOS732mdA
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    Exactly.
    If you don't have a firewall adjuster, just pull up on the clutch pedal.
    The 3650 is one of the smoothest RWD trannies I've ever shifted.
    They powershift SO easily.
    mark
    Pittsburgh
    1,994
    ive a quadrant and a firewall adjuster. just looking for ways to make it a bit smoother if possible. Or maybe this is as smooth as it gets.lol.
    Quote Originally Posted by sporadic View Post
    Exactly.
    02 MG GT
    93 Civic Hatch
  1. tr3650 tricks?
    By jasons_98gt in forum SN95-New Edge
    Last Post: 07-02-2013, 12:01 PM
  2. Wanted: TR3650
    By redfire vert in forum Ford Parts
    Last Post: 10-26-2012, 09:10 AM
  3. Looking for a used tr3650 or maybe a T56
    By Jivepepper in forum Ford Parts
    Last Post: 02-08-2012, 01:14 PM
  4. Shifting prob
    By starliper in forum General Tech
    Last Post: 06-11-2010, 06:29 PM
  5. t56 shifting stops
    By xxtorinoxx in forum SN95-New Edge
    Last Post: 05-12-2009, 08:16 AM
