I've been accumlating parts for far too long & need to clean house.
306/331/347 roller block, bored .030" & zero-decked, only needs a line-hone, $100
Holley Systemax II intake & 3/8" phenolic spacer, $350 SOLD
http://us.a2.yahoofs.com/users/439a6...oU5QFB8f6JJgM2
TFS 1.6 ratio 7/16" stud mount roller rockers, 7/16" studs, polylocks & guideplates
set of 16, with (2) extra rockers very good condition- $175
Holcomb Motorsports Mutha adj. upper upper control arms, NIB, $150
http://us.a2.yahoofs.com/users/439a6...oU5QFBDuGpNThn
Triple hook clutch quadrant & firewall cable adjuster $30 SOLD
3.55 FMS gear & Auburn differential, 28 spline ~25k miles $250
FMS X-303 cam, 224/224 duration, .542/.542" lift used $40
Ultradyne cam 218/218 dur., .525/.525" lift, 112 lca, nice street cam NIB $60
TFS TW .600" lift HR springs, 1500 miles, $25
FTI PS2 Springs 150 miles, .609" lift 145# seat $25
Valve spring retainers for above springs, $25
TFS 6.700" 5/16" diam x .083" wall chromemoly pushrods - $35
BBK 70MM TB & matching egr spacer, $65 SOLD
EEC-IV A3M ecu - $45 SOLD
Pro-M Race 80mm MAF & filter 30# cal '87-93 EEC-IV- $75 SOLD
Pro-M Race 80mm MAF & filter 36# s/c cal '96+ EEC-V - $75
EEC-IV Scan tool, Auto X-Ray OBD-I LCD display scanner, $65
Cobra Clutch & PP, 20K, lots of meat left on disk - $25
PSM Variflow electric fan controller, NIB, $25
Dynagear True Roller timing chain, p/n 78120, NIB, $25
* 76mm turbo - T4 exhaust flange, polished compressor housing, 4" inlet, 2.5" outlet, .96 AR hot side, 3.5" v-band exhaust, jet-hot coated turbine housing. Always run with an air filter. The turbo was purchased new and was been on the car for about 16 months. This was driven as a sunny weekend cruiser and racer at the track. I'd be surprised if the actual mileage on it is above 1000 miles. Ran a 9.32 @ 145 on a 377 windsor.
$850, turbo only. SOLD
Pics supplied upon request.
Mark
