Results 1 to 9 of 9
Thread: 87-93 LX Door Body Mouldings
    Member RUSH2112's Avatar
    Hopewell, PA
    754
    Looking for the door trim mouldings for the driver and passenger doors for an 87-93 LX (NOT GT) mouldings. Must be in excellent shape or new and not wavy or damaged. PM me immediately
    Member madmaxin22's Avatar
    on the red belt
    853
    let me take a look at the ones on the 91 im parting....
    2014 RAM QUAD CAB 8SPD
    Hopewell, PA
    754
    Thanks. Color doesnt matter as they will be repainted, just have to be straight
    Be VERY careful when removing them. There are aluminum strips inside of them that will bend very easy and then they's junk.
    on the red belt
    853
    talk about a PITA to take off... 45 minutes later heres pics of the drivers side... wanted to make sure i could take them off before offering them up...
    sell you the pair for $45 and will meet ya... in good shape and laying flat as you can see....
    Member DING's Avatar
    New Bern, NC
    324
    If you buy used molding you have to remove the metal strip that holds the adhesive on the molding. You will need two people, a torch with map gas, and a pair of pliers to pull on the metal strip. Be careful NOT to get them to HOT. Patience is key. The map gas will loosen the adhesive holding the metal strip to the molding.
    You need to do this to re install them on the car otherwise they will look like shit. Then re install the double side 3M molding tape and reapply to the doors. Its not that bad of a process. Good Luck
    Hank
    FYI, if you don't reinstall the metal strips, the door moldings will actually shrink almost an inch over time.
    2,483
    After finding some of this info the hard and expensive way, I ended up buying 2 NOS strips from ebay for about $190. Even those weren't molded all that great. They had small bumps near the ends and the 3 pieces that were molded together to get each side had poor joints.
    New Bern, NC
    324
    Your right about them shrinking Ed. But the ones I did only shrunk about 3/8 or 1/2 of and inch. Anyway, its better than buying reproduction.
    Hank
  1. Fox body convertible driver door, power windows
    By Tiger40 in forum Ford Vehicles
    Last Post: 08-09-2014, 11:55 PM
  2. WTB 1986 outer belt mouldings
    By 4 eyed mustang in forum Ford Parts
    Last Post: 01-24-2010, 10:48 PM
  3. Replies: 1
    Last Post: 12-20-2009, 04:14 PM
  4. Wanted Fox body passenger door
    By oldfox in forum Ford Parts
    Last Post: 11-16-2009, 07:59 PM
  5. Wanted GT door mouldings 87-93
    Last Post: 09-16-2009, 09:48 PM
