Results 1 to 20 of 23
Thread: Water temp sensor help!?
    Selinsgrove, PA
    526
    Ok, well i just removed the water temp sensor (right of dist. on lower intake) so i could put my mech. water temp quage in, and when i had everything tightened up i removed my pressure cap on radiator to check coolant level, and coolant started to come out of where i just put the mech water temp gauge rod thing... did i do something wrong that coolant is coming out of there!? or what??
    Need help asap!!
    Fox/n.
    LowHill
    2,679
    Did you use teflon tape on the threads? If you did, did you wrap it the opposite way it threads so it doesn't come undone when you thread it? Also did you over tighten and maybe crack the lower intake?
    pa
    860
    Need some Permatex pipe dope on the treads to help stop that or teflon tape . http://www.permatex.com/products/aut...ad_Sealant.htm
    Selinsgrove, PA
    526
    its not coming out like where the threads are, its coming out of the middle of the thing i stuck in the intake.. h/o ill go take a pic..
    Fox/n.
    Mt Pleasant
    2,916
    i know what youre saying. you may not of tightened it enough but be sure not to over tighten it.
    pa
    860
    must of got bent or got a crack
    Selinsgrove, PA
    526
    well its barely tighted at all, because i cant figure out how to tighten it.. lol its 18mm and i dont have an open face wrench that big, and an adjustable is to big to fit in there..
    Fox/n.
    Selinsgrove, PA
    526
    pics are small but hopefully you can see..
    Fox/n.
    LowHill
    2,679
    Thats why it leaking then, your going to have to get the right wrench to do it.
    Mt Pleasant
    2,916
    yep. go buy one if you have too and then just return it if your low on cash, even though i've never done that
    Farmington WV
    4,672
    always a good reason to buy a new tool.
    Selinsgrove, PA
    526
    kk all is good, got a wrench and got it hooked up, thanks guys!!
    Fox/n.
    ILLBEATU fastfox91's Avatar
    huntingdon,pa
    830
    just curios did u put it were the water temp sensor goes or did u put it some were else cause that sensor needs hooked up with out it that car is gonna run like shit
    Mt Pleasant, PA
    4,905
    You can't just screw the nut on there like you have it, there is a fitting that needs to go into the intake first and then the fitting you have screws into the fitting that goes into the intake. That traps the probe between the two.
    out in the woods
    4,948
    why is that???
    i may be mis-reading this,but i've installed temp gauges in that location before and car ran fine. just pull out the factory temp sensor then put the gauge one in it's place.
    why is that???
    the factory coolant temp sensor contributes to the ecu calculation of A/F
    out in the woods
    4,948
    well i've never had any issues with taking the factory sensor out to install an aftermarket gauge...
    huntingdon,pa
    830
    then u have had great luck on your side!
    Petersburg,PA. 16669
    816
    that sensor only works the gauge.The ECT is in the heater pipe
    I still can't figure out what you are doing in the pic though
    88 GT...and some boost
    huntingdon,pa
    830
    thats were i assumed he was putting it
  1. temp garage
    Last Post: 10-08-2011, 11:29 AM
  2. Temp sensor???
    Last Post: 05-16-2010, 06:16 PM
  3. How to convert an ABS sensor into a speedo sensor.
    Last Post: 01-27-2009, 10:46 PM
  4. Water Temp Gauge
    Last Post: 06-06-2008, 01:12 PM
  5. Engine coolant temp. sensor
    By Mr. Rob in forum General Tech
    Last Post: 12-27-2006, 10:19 AM
