Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Water temp sensor help!?
  1. #21
    that sensor only works the gauge.The ECT is in the heater pipe
    I still can't figure out what you are doing in the pic though
    thats what i meant sorry.
  2. #22
    Mt Pleasant, PA
    4,905
    When you buy a mechanical guage it comes with a fitting that screws into the intake and then the probe slides into that and the nut attached to the sending unit of the guage screws into that fitting traping the probe and sealing it. He appears to be trying to screw the nut attached to the guage right into the intake without the other fitting, as a result the probe is able to move around and will not seal.
  3. #23
    Selinsgrove, PA
    526
    Yes i figured it out, the gauge is in, and works fine now... thanks guys!
    Fox/n.
  1. temp garage
    Last Post: 10-08-2011, 11:29 AM
  2. Temp sensor???
    Last Post: 05-16-2010, 06:16 PM
  3. How to convert an ABS sensor into a speedo sensor.
    Last Post: 01-27-2009, 10:46 PM
  4. Water Temp Gauge
    Last Post: 06-06-2008, 01:12 PM
  5. Engine coolant temp. sensor
    By Mr. Rob in forum General Tech
    Last Post: 12-27-2006, 10:19 AM
