Results 1 to 13 of 13
Thread: window tint removal question
    1,164
    i am tinkering with a car i just got from florida.
    it has had window tint for the past several years.
    i want to rmove the stuff.
    i have been peeling it off and using glass cleaner with ammonia.
    even with the film off the window its as if there is a glueish coating on the window. i do not want to gouge the glass by using a razor blade scraping it..but that has been the only way so far if i squirt the winow with cleaner then run the blade over it
    any tips/tricks to get this crap off my windows??
    i was going to try laquer thinner but don't want to ruin the glass.
    Member badstanglx's Avatar
    altoona
    676
    brake cleaner works great to take the glue off
    State College, PA
    3,552
    goo gone works good on that stuff!
    2013 Mustang GT
    1999 Contour SVT
    boats n hoes fork5o's Avatar
    Hopewell
    833
    x2 thats what i used
    -Joe
    1995 5.0
    The Car
    work
    4,057
    x3 what friend had to use after cop pulled him over.
    A razor wont gouge the glass The only thing it will do is remove the defroster, and if it is a Florida car, you dont have one. The razor will be a hell of a lot easier. Otherwise, you will go through a ton of rags wiping, flipping and wiping again.
    Used that and a blade on an old Caddy I had.
    I have used lacquer thinner in the past, works quick.
    real name-Shawn
    plum
    487
    gumout carb cleaner works great!
    Thinner or Rubbing Alcohol bothe will work well.
    Oct 2007
    Baldwin
    259
    ALways use laquer here. Glass is pretty resistant to chemicals. A good single edge razor blade works well too.
    2012 Husqvarna TE 449
    2007 BMW E92 328xi
    2003 F250 Superduty
    2004 SV650
    i tint windows and the way i do it is pull the liner the part with the color off then spray the residu with windex with ammonia and scrape it off with a razor blade
    88 5.0 lx conv eddmann55's Avatar
    irwin
    538
    I agree, brake cleaner and gumout stink, you don't want your interior to smell like there is a carbeurator underneath the drivers seat
  1. Tint removal made easy
    By mustang50lx in forum General Tech
    Last Post: 08-05-2015, 09:51 AM
  2. No more window tint
    By 2002LXSport in forum General Tech
    Last Post: 02-24-2010, 11:10 AM
  3. window tint??
    Last Post: 06-12-2008, 02:11 PM
  4. Window Tint?
    By Balaska347 in forum General Tech
    Last Post: 04-28-2008, 07:28 PM
  5. Window Tint
    By torchred v6 in forum The Bar
    Last Post: 03-26-2008, 09:05 AM
