Hello,
I am listing these parts on behalf of a Friend who is much to busy to sell all of these items. With that said, i'm only the Technical Guy and coordinator. He has the answers on the parts and will accept or deny the price. These parts are in a huge warehouse in Pittsburgh, Pa.
If you have questions OR would like to make an offer - EMAIL or PM.
I have this posted on 10 Forums and cannot check them all.
my email is my username @yahoo - Please no Lowballing - He is in no rush - he's just cleaning out the warehouse - I do have PayPal
If you have a question or offer - EMAIL Me -- my username @ yahoo
ITEM
IRS w/373 gears - whole Rear Suspension - IRS – 26,000 miles, w/new 3.90 ring and pinion w/1200 miles, remmed and expertly installed. Includes shocks
IRS Girdle/Brace (Kenny Brown) - Brace for Rear End
AlumPinion Snubber (mounts on differential)
KB Kool Air Kit - Intake CAI - Kenne Bell 4†Kool Air Kit- Used, wheel well mounted (see Kenne Bell Web site for description) http://www.kennebell.net/contactus/contactus.htm
Ford Cobra Throttle Body (stock)
Eaton Blower Cobra 4.6 stock
Stock Shifter
Subrrame Connectores (Kenny Brown)
Intercooler for 5.4/4.6
SHM Alum Race-prepped block
Ford cobra CAI
Air Bags & accrutriments
SCT X2 Tuning Tool and Programs - SCT Xcalibrator- flash tuning tool preloaded with three separate customized tunes: Street, Race and Factory Original. Requires less than one minute to change tunes. These tunes are specific to this particular engine combination or similarly equipped Cobra, or it can be reprogrammed by any authorized SCT dealer. http://www.sctflash.com/index.php
Kenne Belle Switch Chip
Extra Half Shafts
Ring and Pinion 3:55 - Stock Gears?
Kenne Bell KB Boost a Pump - Fuel Pump Booster
Used M/T ET Street Slicks-pair
Stock Cobra Wheels (2) Fair
Beehive Valve Springs (32)
Mac Mufflers
Bassani X pipe
Mac Cat-back
McLeod 700 HP custom clutch - McLeod Clutch; Custom built by renown clutch expert Walt at Pro Motion Drivetrain. Able to handle up to 800 flywheel horsepower. Very streetable with lighter-than-stock peddle pressure! Less than 5000 street miles and fewer than 20 runs at that track. VERY good condition
Stock Clutch
Stock Flywheel? (avail?)
Complete Engine 715 HP - Metco lower,1% leak,60# inj,accufab TB - Engine- 2003 SVT 32 valve Cobra Engine; 26K miles; fresh valves;<1% leak-down tested, near-perfect! Certifiably generates in excess of 610 RWHP (716 FWHP). Capable of producing 625 RWHP “as is.†60# injectors; Kenne Bell 2.2 Supercharger, Accufab Wide mouth throttle body
SCT Big Air MAF 2400 - mass air meter
JLT Cool Air Intake System - JLT Cold Air Kit- The best rated of all cold air kits for 2003 Cobras. http://www.jlttruecoldair.com/
Bilstein front struts
Front coils
Rear Seats
stock fuel pump
Kenne Bell 2.8 H supercharger
KB Pulleys assortment
SHM Stage 2 Custom Cams
Oil Pan for 5.4 (fits 4.6??)
Windage tray for 5.4 (and ??)
JE Forged Pistons 3.?? Bore
Manifold for Shelby GT500
Twin injector Ford GT intake
Intake/Valley Covers (2)
Snow Methanol-Water Injection
Snow Injection motor (spare)
stock cobra radiator
A/C radiator
A/C Pump
A/C tubing and wiring
A/C condensor tank
Cobra H pipes w/4 cats (only 6K miles)
Cobra Brake Rotors
Cobra Brake Calipers and pads 70%
Cobra K member (stock)
Cobra front coils
Electric Fan Assembly
Various drive belts
Alum Plate w/matching plastic cover
Electric Throttle Control & cables
Plastic Cover for (battery?)
Basani Hi flow cats - Bassani (stainless steel?) X pipe; with or without high flow CATS
Carpet
Cobra Bucket Seats (2)
Rear Speaker Assembly
Cobra console
Emergency Brake handle
Stock Intercooler reserve tank
Washer fluid tank
Cobra ECU unit (w/o harness)
Alum.Oil Pan (Steff's) for Ford GT block
Alum TB adaptor?
Intercooler Cover Plate Shelby GT 500
Ford Racing Blue Valve Covers (fair)
Moon Discs (4)
Space Saver spare
Cobra Heat Exchanger
Stock Cobra Flywheel - Flywheel – OEM Ford
Sisscor Jack
Bracket (Blue body color w/black brace)
Aluminum plate w/plastic cover
BFG Drag Radials 325-17 (15% left)
