Results 1 to 9 of 9
Thread: Calhoun 6.279 and 111.5 MPH
    73 2.3 Turbo Pinto map351's Avatar
    Leechburgistain Mainland,Cuba
    1,534
    Thumbs up Calhoun 6.279 and 111.5 MPH
    Just got off the phone with J.B. Calhoun and wanted to let everyone know he finally put the shakedown passes on his new Pinto.He only has an eigth mile track to play in,but the numbers are impressive.He ran a 6.279 and 111.5 MPH.The 60' was a little off at 1.5,but the car is spinning off the line and on gear changes and he has a few tune problems to work out with fuel pressure and boost.By the time the suspension is dialed in and all the tuning is complete it should be capable of 5's in the eigth and high 8's in the quarter."CONGRATULATIONS BRAD"You are definately kicking ass with a completely home built car.
    Thanks everyone. Thanks Brady for taking the videos.
    Especially thanks to Jon Dell Blair for troubleshooting the fuel problems and a great tune.
    It is a fun ride for sure! Next time might have to add in the nitrous to spool up faster!
    Brad Calhoun
    Here's the Vid>> http://videos.streetfire.net/video/5...6901667751.htm
    289 slabside cobra
    6S1941
    40 Ford Sedan Delivery < For Sale
    Nice runs
    street car?
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    Member Darrell's Avatar
    Fond du Lac, Wisconsin
    23
    Holy christ that thing is flying!!!!!
    1990 Mustang LX
    naturally aspirated TEA Trick Flow R headed small block, C4, 3016 lbs, stock suspension, 28x10.5
    9.36 at 143 mph
    Banned. shawnsvtcobra's Avatar
    Altoona,Pennsylvania
    2,016
    That little sucker flys.
    wow thats awsome what turbo is he running?
    1,534
    This is Brads engine..
    short block mods/compression ratio/displacement: .030 Block w/Honda Oil Squirters - 9.0 JE flat top Forged Pistons - Esslinger windage tray - ARP Studs - Crower Sportsman 5.5" Rod w/cap screws - Stock Crank - Piston pins Floated - About 143 cu in
    head/port work/valve size:Out of the box stock Esslinger SVO Aluminum Head
    cam specs/degrees adv-ret:Esslinger Solid Roller Cam - 262 duration @ .050 - .655 lift - 300 average duration - 111.5 centerline - Running the cam straight up
    intake/throttle body: Wilson 90mm
    intercooler:Air/Water
    nitrous system/shot size:250 shot installed but not yet being used
    exhaust manifold:Custom center mount Rods SS header
    turbo: SC6176E
    wastegate:Turbosmart 38mm
    exhaust size:4" down pipe only engine management:FAST B2B
    a/f ratio, total timing, boost:11.5 - 25 - 30
    fuel octane/brand/leaded or unleaded:VP C16 leaded
    hp@rpm:Doing the math works out to be about 540RWHP
    trq@rpm:
    flex plate/flywheel:Reactor Flex Plate
    convertor/clutch:Coan 7" converter
    transmission:C4 w/PA Brake
    rear/ratio/tire type/tire size:8.8- Strange Full Spool & Strange Axles- 4.56 - MT 28.0 X 9.0 X 15 inflated to 9psi
    289 slabside cobra
    6S1941
    Sexy and i know it fast4ord's Avatar
    Gibsonia
    772
    Badass
    My collection:
    01 cobra in pieces
    02 dodge cummins
    LowHill
    2,679
    WOW thats awesome
    1,534
    Thumbs up
    Brad Calhoun ran his 2.3 Turbo Pinto last night and was running consistent 5.85 - 5.86 1/8 mile ET's with MPH from 115 to 117. With 1.25 60'
    http://s6.photobucket.com/albums/y25...nt=Penwell.flv
    289 slabside cobra
    6S1941
  1. The 100 MPH Goat!
    By map351 in forum The Bar
    Last Post: 12-13-2010, 02:22 PM
  2. MPH where the ODO is at
    By Jper in forum The Bar
    Last Post: 12-02-2008, 12:31 AM
  3. Where's my MPH?
    By Stangman701 in forum SN95-New Edge
    Last Post: 12-01-2008, 05:45 PM
  4. 8.168 at 155.78 MPH Is this the Future!
    By map351 in forum Pictures & Videos
    Last Post: 08-06-2007, 12:16 AM
  5. 9.66 @141 mph Track rental
    By mikeymustang in forum Pictures & Videos
    Last Post: 10-18-2006, 08:57 AM
